Branching rules revisited, Operations Research Letters, vol.33, pp.42-54, 2005. ,
Finding cuts in TSP, 1995. ,
Branch-and-price: column generation for solving huge integer programs, Operations Research, vol.46, pp.316-329, 1998. ,
Special facilities in a general mathematical programming system for non-convex problems using ordered sets of variables, Proceedings of the Fifth International Conference on Operational Research, 1970. ,
Experiments in mixed-integer programming, Mathematical Programming, vol.1, pp.71-94, 1971. ,
Exact procedures for solving the discrete ordered median problem, Computers & Operations Research, vol.33, issue.11, pp.3270-3300, 2006. ,
Optimizing the Cargo Express Service of Swiss Federal Railways, Transportation Science, vol.42, issue.4, pp.450-465, 2008. ,
Linear Programming, 1983. ,
An extended version of a Branch-Priceand-Cut Procedure for the Discrete Ordered Median Problem, pp.2158317-2158318, 2018. ,
A primer in column generation, Column Generation, 2005. ,
A constraint-programming-based branch-andprice-and-cut approach for operating room planning and scheduling, INFORMS Journal on Computing, vol.28, issue.3, pp.432-448, 2016. ,
Stabilized column generation, Discrete Mathematics, vol.194, pp.229-237, 1999. ,
1894) A Fourier-féle mechanikai elv alkalmazásai, Mathematikaí es Természettudományí Erstesitö, issue.12, pp.457-472 ,
A probabilistic heuristic for a computationally difficult set covering problem, Operations Research Letters, vol.8, pp.67-71, 1989. ,
Greedy ramdomized adaptive search procedures, Journal of Global Optimization, vol.6, pp.109-133, 1995. ,
On Discrete Optimization with Ordering, Annals of Operations Research, vol.207, issue.1, pp.83-96, 2013. ,
Ordered Weighted Average Combinatorial Optimization: Formulations and their properties, Discrete Applied Mathematics, vol.169, issue.31, pp.97-118, 2014. ,
Ordered Weighted Average Optimization in Multiobjective Spanning Tree Problems, European Journal of Operational Research, vol.260, issue.31, pp.886-903, 2017. ,
Generic Branch-Cut-and-Price, 2010. ,
The SCIP optimization suite 3.2, 2016. ,
A Branch-and-Price Algorithm and New Test Problems for Spectrum Auctions, Management Science, vol.51, issue.3, pp.391-406, 2005. ,
Modeling and Strong Linear Programs for Mixed Integer Programming, Algorithms and Model Formulations in Mathematical Programming, pp.978-981, 1989. ,
A comparative study of formulations and solution methods for the discrete ordered p-median problem, Computers & Operations Research, vol.78, pp.230-242, 2017. ,
A flexible model and efficient solution strategies for discrete location problems, Discrete Applied Mathematics, vol.157, issue.5, pp.1128-1145, 2009. ,
An extended covering model for flexible discrete and equity location problems, Mathematical Methods of Operations Research, vol.71, issue.1, pp.125-163, 2010. ,
Discrete ordered weber problems, Operations Research Proceedings, pp.71-76, 2000. ,
A unified approach to network location problems, Networks, vol.34, pp.283-290, 1999. ,
Location Theory: A Unified Approach, 2005. ,
Finding the nucleolus of any n?person cooperative game by a single linear program, Computers & Operations Research, vol.40, issue.10, pp.2308-2313, 2013. ,
Exact Algorithm over an ArctimeIndexed Formulation for Parallel Machine Scheduling Problems, Mathematical Programming Computation, vol.2, pp.259-290, 2010. ,
Mathematical programming formulations for the efficient solution of the k-sum approval voting problem, Computers & Operations Research, vol.98, pp.127-136, 2018. ,
A new formulation of the capacitated discrete ordered median problem with {0, 1}-assignment, Operations Research Proceedings, pp.165-170, 2007. ,
Geometrical properties of the symmetrical single facility location problem, Journal of Nonlinear and Convex Analysis, vol.1, issue.3, pp.321-342, 2000. ,
A modified variable neighborhood search for the discrete ordered median problem, European Journal of Operational Research, vol.234, pp.61-76, 2014. ,
Minimax regret single-facility ordered median location problems on networks, INFORMS Journal on Computing, vol.21, issue.1, pp.77-87, 2009. ,
Single-allocation ordered median hub location problems, Computers & Operations Research, vol.38, issue.2, pp.559-570, 2011. ,
A specialized Branch & Bound & Cut for Single-Allocation Ordered Median Hub Location problems, Discrete Applied Mathematics, vol.161, pp.2624-2646, 2013. ,
Ordered Median Hub Location Problems with Capacity Constraints, Transportation Research Part C: Emerging Technologies, vol.70, pp.142-156, 2016. ,
AM Ordered Median Location Problems, Location Science, 2015. ,
An integer programming approach to scheduling. Wren A, Computer Scheduling of Public Transport: Urban Passenger Vehicle and Crew Scheduling, pp.269-280, 1981. ,
Integer programming, 1998. ,
