Fast 3D frequency-domain full waveform inversion with a parallel Block Low-Rank multifrontal direct solver: application to OBC data from the North Sea, Geophysics, vol.81, pp.363-383, 2016. ,
DOI : 10.1190/geo2016-0052.1
URL : https://hal.archives-ouvertes.fr/hal-01349119
On computing inverse entries of a sparse matrix in an out-of-core environment, SIAM Journal on Scientific Computing, vol.34, pp.1975-1999, 2012. ,
URL : https://hal.archives-ouvertes.fr/hal-00763556
Parallel computation of entries of A-1, SIAM Journal on Scientific Computing, vol.37, pp.268-284, 2015. ,
URL : https://hal.archives-ouvertes.fr/hal-00759556
On exploiting sparsity of multiple right-hand sides in sparse direct solvers, 2017. ,
URL : https://hal.archives-ouvertes.fr/hal-01955659
Sparse marix reordering schemes for browsing hypertext, Lecture notes in applied mathematic, vol.32, pp.99-124, 1996. ,
A set of level 3 basic linear algebra subprograms, ACM Trans. Math. Softw, vol.16, pp.1-17, 1990. ,
DOI : 10.1145/77626.79170
, Direct Methods for Sparse Matrices, 2017.
The theory of elimination trees for sparse unsymmetric matrices, SIAM Journal on Matrix Analysis and Applications, vol.26, pp.686-705, 2005. ,
Nested dissection of a regular finite-element mesh, SIAM Journal on Numerical Analysis, vol.10, pp.345-363, 1973. ,
DOI : 10.1137/0710032
Predicting structure in sparse matrix computations, SIAM Journal on Matrix Analysis and Applications, vol.15, pp.62-79, 1994. ,
DOI : 10.1137/s0895479887139455
URL : https://ecommons.cornell.edu/bitstream/1813/6590/1/86-750.pdf
Elimination structures for unsymmetric sparse LU factors, SIAM Journal on Matrix Analysis and Applications, vol.14, pp.334-352, 1993. ,
DOI : 10.1137/0614024
The role of elimination trees in sparse factorization, SIAM Journal on Matrix Analysis and Applications, vol.11, pp.134-172, 1990. ,
Reducing the total bandwidth of a sparse unsymmetric matrix, SIAM Journal on Matrix Analysis and Applications, vol.28, pp.805-821, 2006. ,
Large-scale 3D EM modeling with a Block Low-Rank multifrontal direct solver, Geophysical Journal International, vol.209, pp.1558-1571, 2017. ,
DOI : 10.1093/gji/ggx106
URL : https://hal.archives-ouvertes.fr/hal-01672952
Parallel triangular solution in the out-of-core multifrontal approach for solving large sparse linear systems, 2009. ,
On partitioning and reordering problems in a hierarchically parallel hybrid linear solver, 2013 IEEE 27th International Parallel and Distributed Processing Symposium Workshops & PhD Forum (IPDPSW), pp.1391-1400, 2013. ,
DOI : 10.1109/ipdpsw.2013.170
URL : https://hal.archives-ouvertes.fr/hal-00923447
Interactively cutting and constraining vertices in meshes using augmented matrices, ACM Trans. Graph, vol.35, p.17, 2016. ,
DOI : 10.1145/2856317
URL : http://dl.acm.org/ft_gateway.cfm?id=2856317&type=pdf
AMPS: an augmented matrix formulation for principal submatrix updates with application to power grids, SIAM Journal on Scientific Computing, vol.39, pp.809-827, 2017. ,
DOI : 10.1137/16m1082755
URL : http://arxiv.org/pdf/1706.03147
