Conference papers
Certified dimension reduction of the input parameter space of multivariate functions
Olivier Zahm 1
1 AIRSEA - Mathematics and computing applied to oceanic and atmospheric flows
UGA [2016-2019] - Université Grenoble Alpes [2016-2019], Grenoble INP [2007-2019] - Institut polytechnique de Grenoble - Grenoble Institute of Technology [2007-2019], LJK - Laboratoire Jean Kuntzmann , Inria Grenoble - Rhône-Alpes
Abstract : Approximation of multivariate functions is a difficult task when the number of input parameters is large. Identifying the directions where the function does not significantly vary is a key preprocessing step to reduce the complexity of the problem we have at hand. We propose a gradient based method that permits to detect such a low-dimensional structure of a function. Our methodology consists in minimizing an upper-bound of the approximation error obtained using Poincaré-type inequalities, and it generalizes the Active Subspace method. Numerical examples reveals the importance of the choice of the metric to measure errors and compare it with the commonly used truncated Karhunen-Loeve decomposition. We also show that the same methodology can be applied for the reduction of the dimension of Bayesian inverse problems. By seeking an approximation of the likelihood function by a ridge function, the resulting method exploits the fact that the data are not informative over the whole parameter space but only on a low-dimensional subspace.
Document type :
Conference papers
Complete list of metadatas
https://hal.inria.fr/hal-01955812
Contributor : Olivier Zahm <>
Submitted on : Friday, December 14, 2018 - 4:03:21 PM
Last modification on : Wednesday, October 7, 2020 - 1:12:02 PM
Identifiers
  • HAL Id : hal-01955812, version 1
Collections
Citation
Olivier Zahm. Certified dimension reduction of the input parameter space of multivariate functions. Journées EDP Auvergne-Rhône-Alpes, Nov 2018, Grenoble, France. ⟨hal-01955812⟩
Share
Metrics
Record views
111
