The Assignment Problem - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2018
In the allocation problem, asynchronous processors must partition a set of items so that each processor leave knowing all items exclusively allocated to it. We introduce a new variant of the allocation problem called the assignment problem, in which processors might leave having only partial knowledge of their assigned items. The missing items in a processor's assignment must eventually be announced by other processors. While allocation has consensus power 2, we show that the assignment problem is solvable read-write wait-free when k processors compete for at least 2k − 1 items. Moreover, we propose a long-lived read-write wait-free assignment algorithm which is fair, allocating no more than 2 items per processor, and in which a slow processor may delay the assignment of at most n items, where n is the number of processors. The assignment problem and its read-write solution may be of practical interest for implementing resource allocators and work queues, which are pervasive concurrent programming patterns, as well as stream-processing systems.
final.pdf (864.57 Ko) Télécharger le fichier
hal-01955902 , version 1 (14-12-2018)
  • HAL Id : hal-01955902 , version 1
Carole Delporte-Gallet, Hugues Fauconnier, Eli Gafni, Giuliano Losa. The Assignment Problem. International Conference on Distributed Computing and Networking, {ICDCN}, 2018, Varanasi, India. ⟨hal-01955902⟩
72 Consultations
82 Téléchargements
