Access-Time-Aware Cache Algorithms - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue ACM Transactions on Modeling and Performance Evaluation of Computing Systems Année : 2017
Giovanni Neglia
Damiano Carra
  • Fonction : Auteur
  • PersonId : 865031
Mingdong Feng
  • Fonction : Auteur
  • PersonId : 980176
Pietro Michiardi
  • Fonction : Auteur
  • PersonId : 1084771
Most of the caching algorithms are oblivious to requests' timescale, but caching systems are capacity constrained and, in practical cases, the hit rate may be limited by the cache's impossibility to serve requests fast enough. In particular, the hard-disk access time can be the key factor capping cache performance. In this paper, we present a new cache replacement policy that takes advantage of a hierarchical caching architecture, and in particular of access-time difference between memory and disk. Our policy is optimal when requests follow the independent reference model, and significantly reduces the hard-disk load, as shown also by our realistic, trace-driven evaluation. Moreover, we show that our policy can be considered in a more general context, since it can be easily adapted to minimize any retrieval cost, as far as costs add over cache misses.
00_access_time_aware_caching (1).pdf (1.23 Mo) Télécharger le fichier
hal-01956285 , version 1 (15-12-2018)
Giovanni Neglia, Damiano Carra, Mingdong Feng, Vaishnav Janardhan, Pietro Michiardi, et al.. Access-Time-Aware Cache Algorithms. ACM Transactions on Modeling and Performance Evaluation of Computing Systems, 2017, 2 (4), pp.1-29. ⟨10.1145/3149001⟩. ⟨hal-01956285⟩
103 Consultations
254 Téléchargements
