Implicit Coordination of Caches in Small Cell Networks under Unknown Popularity Profiles - Archive ouverte HAL Access content directly
Journal Articles IEEE Journal on Selected Areas in Communications Year : 2018
(1) , (2)
1
2
We focus on a dense cellular network, in which a limited-size cache is available at every Base Station (BS). In order to optimize the overall performance of the system in such scenario, where a significant fraction of the users is covered by several BSs, a tight coordination among nearby caches is needed. To this end, this paper introduces a class of simple and fully distributed caching policies, which require neither direct communication among BSs, nor a priori knowledge of content popularity. Furthermore, we propose a novel approximate analytical methodology to assess the performance of interacting caches under such policies. Our approach builds upon the well known characteristic time approximation [1] and provides predictions that are surprisingly accurate (hardly distinguishable from the simulations) in most of the scenarios. Both synthetic and trace-driven results show that the our caching policies achieve excellent performance (in some cases provably optimal). They outperform state-of-the-art dynamic policies for interacting caches, and, in some cases, also the greedy content placement, which is known to be the best performing polynomial algorithm under static and perfectly-known content popularity profiles.
1804.01895(2).pdf (2.06 Mo) Télécharger le fichier
Dates and versions
hal-01956307 , version 1 (15-12-2018)
Identifiers
Cite
Emilio Leonardi, Giovanni Neglia. Implicit Coordination of Caches in Small Cell Networks under Unknown Popularity Profiles. IEEE Journal on Selected Areas in Communications, 2018, 36 (6), pp.1276-1285. ⟨10.1109/JSAC.2018.2844982⟩. ⟨hal-01956307⟩
30 View
106 Download
Share
