Cost-aware caching: Caching more (costly items) for less (ISPs operational expenditures)," Parallel and Distributed Systems, IEEE Trans. on, vol.27, issue.5, pp.1316-1330, 2016. ,
Coordinated selfish distributed caching for peering content-centric networks, IEEE/ACM Trans. on Networking, 2016. ,
On designing optimal memory damage aware caching policies for content-centric networks, Proc. of WiOpt, pp.163-170, 2016. ,
Access-time aware cache algorithms, Proc. of ITC-28, 2016. ,
URL : https://hal.archives-ouvertes.fr/hal-01402425
, Encyclopedia of Algorithms, pp.601-604, 2008.
A Utility Optimization Approach to Network Cache Design, Proc. of IEEE INFOCOM 2016, 2016. ,
URL : https://hal.archives-ouvertes.fr/hal-01377841
Performance evaluation of hierarchical TTL-based cache networks, Computer Networks, vol.65, pp.212-231, 2014. ,
URL : https://hal.archives-ouvertes.fr/hal-01094694
Competitive paging algorithms, Journal of Algorithms, vol.12, pp.685-699, 1991. ,
Online primal-dual algorithms for covering and packing problems, Proc. of 13th Annual European Symposium on Algorithms (ESA 2005), 2005. ,
Competitive online algorithms, BRIC, Lecture Series LS, pp.96-98, 1996. ,
On-line file caching, Algorithmica, vol.33, issue.3, pp.371-383, 2002. ,
Cost-aware www proxy caching algorithms, Proc. of the USENIX USITS, 1997. ,
Asymptotic miss ratios over independent references, Journal of Computer and System Sciences, vol.14, issue.2, pp.222-250, 1977. ,
Hierarchical Web caching systems: modeling, design and experimental results, IEEE Journal on, vol.20, issue.7, pp.1305-1314, 2002. ,
A versatile and accurate approximation for LRU cache performance, Proceedings of the 24th International Teletraffic Congress, p.8, 2012. ,
URL : https://hal.archives-ouvertes.fr/hal-00671937
A unified approach to the performance analysis of caching systems, ACM Trans. Model. Perform. Eval. Comput. Syst, vol.1, issue.3, p.28, 2016. ,
Optimizing LRU Caching for Variable Document Sizes, Comb. Probab. Comput, vol.13, issue.4-5, pp.627-643, 2004. ,
The Evolution of Conventions, Econometrica, vol.61, issue.1, pp.57-84, 1993. ,
Measurement-based self organization of interfering 802.11 wireless access networks, Proc. of IEEE INFOCOM, pp.1451-1459, 2007. ,
The online knapsack problem: Advice and randomization, Theor. Comput. Sci, vol.527, pp.61-72, 2014. ,
, Simulated Annealing: Theory and Applications, 1987.
Simulated Annealing method with general acceptance probabilities, Journal of Applied Probability, vol.24, issue.3, pp.657-667, 1987. ,
Cooling schedules for optimal annealing, Mathematics of Operations Research, vol.13, 1988. ,
Markov chains with rare transitions and simulated annealing, Math. Oper. Res, vol.14, issue.1, pp.70-90, 1989. ,
, Individual Strategy and Social Structure: An Evolutionary Theory of Institutions, 2001.
Network applications of bloom filters: A survey, Internet Math, vol.1, issue.4, pp.485-509, 2003. ,
Popularity-driven content caching, Proc. of IEEE INFOCOM 2016, 2016. ,
Placing dynamic content in caches with small population, Proc. of IEEE INFOCOM 2016, 2016. ,
Modeling conservative updates in multi-hash approximate count sketches, Proc. of ITC-24, 2012. ,
Continuous Inspection Schemes, Biometrika, vol.41, issue.1-2, pp.100-115, 1954. ,
The CUSUM algorithm a small review, 2012. ,
URL : https://hal.archives-ouvertes.fr/hal-00914697
An O(1) algorithm for implementing the LFU cache eviction scheme, 2010. ,
, Probability with Martingales, 1991.
Ergodicity in parametric non stationary Markov chains: An application to simulated annealing methods, Operations Research, vol.35, issue.6, pp.867-874, 1987. ,
Markov chains : Gibbs fields, Monte Carlo simulation and queues, 1999. ,
Detection of Abrupt Changes: Theory and Application, 1993. ,
URL : https://hal.archives-ouvertes.fr/hal-00008518
