New interface
Conference papers
Large-Scale Optimal Transport and Mapping Estimation
Abstract : This paper presents a novel two-step approach for the fundamental problem of learning an optimal map from one distribution to another. First, we learn an optimal transport (OT) plan, which can be thought as a one-to-many map between the two distributions. To that end, we propose a stochastic dual approach of regularized OT, and show empirically that it scales better than a recent related approach when the amount of samples is very large. Second, we estimate a \textit{Monge map} as a deep neural network learned by approximating the barycentric projection of the previously-obtained OT plan. This parameterization allows generalization of the mapping outside the support of the input measure. We prove two theoretical stability results of regularized OT which show that our estimations converge to the OT plan and Monge map between the underlying continuous measures. We showcase our proposed approach on two applications: domain adaptation and generative modeling.
Complete list of metadata
https://hal.inria.fr/hal-01956354
Contributor : Nicolas Courty Connect in order to contact the contributor
Submitted on : Saturday, December 15, 2018 - 3:26:20 PM
Last modification on : Friday, August 5, 2022 - 2:54:52 PM
Links full text
Identifiers
  • HAL Id : hal-01956354, version 1
  • ARXIV : 1711.02283
Citation
Vivien Seguy, Bharath Bhushan Damodaran, Remi Flamary, Nicolas Courty, Antoine Rolet, et al.. Large-Scale Optimal Transport and Mapping Estimation. ICLR 2018 - International Conference on Learning Representations, Apr 2018, Vancouver, Canada. pp.1-15. ⟨hal-01956354⟩
Share
Metrics
Record views
189
