DeepJDOT: Deep Joint Distribution Optimal Transport for Unsupervised Domain Adaptation - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2018
In computer vision, one is often confronted with problems of domain shifts, which occur when one applies a classifier trained on a source dataset to target data sharing similar characteristics (e.g. same classes), but also different latent data structures (e.g. different acquisition conditions). In such a situation, the model will perform poorly on the new data, since the classifier is specialized to recognize visual cues specific to the source domain. In this work we explore a solution, named DeepJDOT, to tackle this problem: through a measure of discrepancy on joint deep representations/labels based on optimal transport, we not only learn new data representations aligned between the source and target domain, but also simultaneously preserve the discriminative information used by the classifier. We applied DeepJDOT to a series of visual recognition tasks, where it compares favorably against state-of-the-art deep domain adaptation methods.
hal-01956356 , version 1 (15-12-2018)
Bharath Bhushan Damodaran, Benjamin Kellenberger, Remi Flamary, Devis Tuia, Nicolas Courty. DeepJDOT: Deep Joint Distribution Optimal Transport for Unsupervised Domain Adaptation. ECCV 2018 - 15th European Conference on Computer Vision, Sep 2018, Munich, Germany. pp.467-483, ⟨10.1007/978-3-030-01225-0_28⟩. ⟨hal-01956356⟩
335 Consultations
0 Téléchargements
