Block Low-rank Algebraic Clustering for Sparse Direct Solvers - Archive ouverte HAL Access content directly
Conference Papers Year :
(1) , (2) , (1) , (3) , (1)
1
2
3
We will discuss challenges in building clusters for the Block Low-Rank (BLR) approach, for nodes inside separators appearing during the factorization of sparse matrices. We will illustrate limitations for methods that consider only intra-separators connectivity (i.e., k-way and recursive bisection) as well as methods focusing only on reducing the number of updates between separators. The new strategy we propose considers interactions between a separator and its children in the nested dissection. It allows reducing the computational cost of BLR, and the number of off-diagonal blocks. We demonstrate that this method enhances the BLR strategies in the sparse direct supernodal solver PaStiX, and discuss how it can be extended to low-rank formats with more than one level of hierarchy.
Not file
Dates and versions
hal-01956962 , version 1 (16-12-2018)
Identifiers
  • HAL Id : hal-01956962 , version 1
Cite
Grégoire Pichon, Eric Darve, Mathieu Faverge, Pierre Ramet, Jean Roman. Block Low-rank Algebraic Clustering for Sparse Direct Solvers. SIAM Conference on Computational Science and Engineering (CSE19), Feb 2019, Spokane, United States. ⟨hal-01956962⟩
121 View
0 Download
Share
