Rank quasi cyclic (RQC). first round submission to the NIST post-quantum cryptography call, 2017. ,
URL : https://hal.archives-ouvertes.fr/hal-01946894
More on average case vs approximation complexity, Computational Complexity, vol.20, issue.4, pp.755-786, 2011. ,
LAKELow rAnk parity check codes Key Exchange-. first round submission to the NIST post-quantum cryptography call, 2017. ,
LOCKER-LOw rank parity ChecK codes EncRyption-. first round submission to the NIST post-quantum cryptography call, 2017. ,
URL : https://hal.archives-ouvertes.fr/hal-01946962
Ranksign-a signature proposal for the NIST's call-. first round submission to the NIST post-quantum cryptography call, 2017. ,
Decoding random binary linear codes in 2 n/20 : How 1 + 1 = 0 improves information set decoding, Advances in Cryptology-EUROCRYPT 2012, 2012. ,
On the inherent intractability of certain coding problems, IEEE Trans. Inform. Theory, vol.24, issue.3, pp.384-386, 1978. ,
Smaller decoding exponents: ball-collision decoding, Advances in Cryptology-CRYPTO 2011, vol.6841, pp.743-760, 2011. ,
Identity-based encryption from the Weil pairing, Advances in Cryptology-CRYPTO, vol.2139, pp.213-229, 2001. ,
Optimizing BJMM with Nearest Neighbors: Full Decoding in 2 2/21n and McEliece Security, WCC Workshop on Coding and Cryptography, 2017. ,
The computational complexity of some problems of linear algebra, J. Comput. System Sci, vol.58, issue.3, pp.572-596, 1999. ,
Efficient zero-knowledge authentication based on a linear algebra problem MinRank, Advances in Cryptology-ASIACRYPT, vol.2248, pp.402-421, 2001. ,
How to achieve a McEliece-based digital signature scheme, Advances in Cryptology-ASIACRYPT, vol.2248, pp.157-174, 2001. ,
DOI : 10.1007/3-540-45682-1_10
URL : https://hal.archives-ouvertes.fr/inria-00072511
, , 2017.
From selective IBE to full IBE and selective HIBE, Theory of Cryptography-15th International Conference, pp.372-408, 2017. ,
Identity-based encryption from the Diffie-Hellman assumption, Advances in Cryptology-CRYPTO 2017, vol.10401, pp.537-569, 2017. ,
New constructions of identity-based and key-dependent message secure encryption schemes, Public-Key Cryptography-PKC 2018, vol.10769, pp.3-31, 2018. ,
On minimum distance decoding of linear codes, Proc. 5th Joint Soviet-Swedish Int. Workshop Inform. Theory, pp.50-52, 1991. ,
Computing loci of rank defects of linear matrices using gröbner bases and applications to cryptology, Symbolic and Algebraic Computation, International Symposium, ISSAC 2010, pp.257-264, 2010. ,
Cryptanalysis of Minrank, Advances in Cryptology-CRYPTO 2008, vol.5157, pp.280-296, 2008. ,
Security bounds for the design of codebased cryptosystems, Advances in Cryptology-ASIACRYPT 2009, vol.5912, pp.88-105, 2009. ,
Attacks and counter-attacks on the GPT public key cryptosystem, Des. Codes Cryptogr, vol.48, issue.2, pp.171-177, 2008. ,
Modified GPT PKC with right scrambler, Electron. Notes Discrete Math, vol.6, pp.168-177, 2001. ,
Ideals over a noncommutative ring and their applications to cryptography, Advances in Cryptology-EUROCRYPT'91, number 547 in LNCS, pp.482-489, 1991. ,
Identity-based encryption from rank metric, Advances in CryptologyCRYPTO2017, volume 10403 of LNCS, pp.194-226, 2017. ,
DOI : 10.1007/978-3-319-63697-9_7
URL : https://hal.archives-ouvertes.fr/hal-01589463
Low rank parity check codes and their application to cryptography, Proceedings of the Workshop on Coding and Cryptography WCC'2013, 2013. ,
URL : https://hal.archives-ouvertes.fr/hal-00913719
On the complexity of the rank syndrome decoding problem. CoRR, abs/1301.1026, 2013. ,
URL : https://hal.archives-ouvertes.fr/hal-01280904
On the complexity of the rank syndrome decoding problem, IEEE Trans. Information Theory, vol.62, issue.2, pp.1006-1019, 2016. ,
New results for rank-based cryptography, Progress in Cryptology-AFRICACRYPT 2014, vol.8469, pp.1-12, 2014. ,
URL : https://hal.archives-ouvertes.fr/hal-01261421
Ranksign: An efficient signature algorithm based on the rank metric (extended version on arxiv), Post-Quantum Cryptography, vol.8772, pp.88-107, 2014. ,
On the hardness of the decoding and the minimum distance problems for rank codes, IEEE Trans. Information Theory, vol.62, issue.12, pp.7245-7252, 2016. ,
URL : https://hal.archives-ouvertes.fr/hal-01443111
Trapdoors for hard lattices and new cryptographic constructions, Proceedings of the fortieth annual ACM symposium on Theory of computing, pp.197-206, 2008. ,
DOI : 10.1145/1374376.1374407
Cryptanalysis of the HFE public key cryptosystem by relinearization, Advances in Cryptology-CRYPTO'99, vol.1666, pp.19-30, 1999. ,
An observation on the security of McEliece's public-key cryptosystem, Advances in Cryptology-EUROCRYPT'88, vol.330, pp.275-280, 1988. ,
Asymptotic behaviour of codes in rank metric over finite fields, Des. Codes Cryptogr, vol.71, issue.1, pp.105-118, 2014. ,
URL : https://hal.archives-ouvertes.fr/hal-00745087
Decoding random linear codes in O(2 0.054n ), Advances in Cryptology-ASIACRYPT 2011, vol.7073, pp.107-124, 2011. ,
DOI : 10.1007/978-3-642-25385-0_6
URL : https://link.springer.com/content/pdf/10.1007%2F978-3-642-25385-0_6.pdf
On computing nearest neighbors with applications to decoding of binary linear codes, Advances in Cryptology-EUROCRYPT 2015, vol.9056, pp.203-228, 2015. ,
Knapsack-type cryptosystems and algebraic coding theory. Problems of Control and Information Theory, vol.15, pp.159-166, 1986. ,
The use of information sets in decoding cyclic codes, IRE Transactions on Information Theory, vol.8, issue.5, pp.5-9, 1962. ,
Cryptosystems based on pairing, SCIS 2000, 2000. ,
Identity-based cryptosystems and signature schemes, Advances in Cryptology-CRYPTO, vol.84, pp.47-53, 1984. ,
DOI : 10.1007/3-540-39568-7_5
Résolution de systèmes multi-homogènes et determinantiels, 2012. ,
A method for finding codewords of small weight, Coding Theory and Applications, vol.388, pp.106-113, 1988. ,
