, , 2016.
, Two-stage two-dimensional guillotine cutting stock problems with usable leftover, International Transactions in Operational Research, vol.23, issue.1-2, pp.121-145
, , 1985.
, Algorithms for unconstrained two-dimensional guillotine cutting, Journal of the Operational Research Society, vol.36, issue.4, pp.297-306
, , 1987.
, Two-dimensional finite bin-packing algorithms, Journal of the Operational Research Society, vol.38, issue.5, pp.423-429
, , 2008.
, Algorithms for two-dimensional cutting stock and strip packing problems using dynamic programming and column generation, European Journal of Operational Research, vol.191, issue.1, pp.61-85
Combining dynamic programming with filtering to solve a four-stage two-dimensional guillotine-cut bounded knapsack problem. Discrete Optimization, 2018. ,
Exact algorithms for the two-dimensional guillotine knapsack, Computers & Operations Research, vol.39, issue.1, pp.48-53, 2012. ,
, , 2014.
, A Variable Neighborhood Search Using Very Large Neighborhood Structures for the 3-Staged 2-Dimensional Cutting Stock Problem, pp.85-99
, , 2015.
, Solving the 3-staged 2-dimensional cutting stock problem by dynamic programming and variable neighborhood search, Electronic Notes in Discrete Mathematics, vol.47, pp.133-140
, , 2012.
, A column generation heuristic for the two-dimensional two-staged guillotine cutting stock problem with multiple stock size, European Journal of Operational Research, vol.218, issue.1, pp.251-260
, , 2016.
, Modeling two-dimensional guillotine cutting problems via integer programming, INFORMS Journal on Computing, vol.28, issue.4, pp.736-751
, , 2007.
, A hybrid genetic algorithm for the two-dimensional single large object placement problem
, European Journal of Operational Research, vol.183, issue.3, pp.1150-1166
Limited discrepancy search, Proceedings of the 14th international joint conference on Artificial intelligence (IJCAI'95), vol.1, pp.607-615, 1995. ,
, , 1998.
, Exact solution of the two-dimensional finite bin packing problem, Management Science, vol.44, issue.3, pp.388-399
, , 2007.
, Models and algorithms for three-stage two-dimensional bin packing, European Journal of Operational Research, vol.183, issue.3, pp.1304-1327
Solving a Real-World Glass Cutting Problem, pp.165-176, 2004. ,
URL : https://hal.archives-ouvertes.fr/hal-01298048
, , 2014.
, An exact dynamic programming algorithm for large-scale unconstrained two-dimensional guillotine cutting problems, Computers & Operations Research, vol.50, pp.97-114
, , 2018.
, Primal heuristics for branch-and-price: the assets of diving methods, INFORMS Journal on Computing
, , 2010.
, An integer programming model for two-and three-stage two-dimensional cutting stock problems, European Journal of Operational Research, vol.205, issue.3, pp.699-708
, , 2001.
, A nested decomposition approach to a three-stage, two-dimensional cutting-stock problem, Management Science, vol.47, issue.6, pp.864-879
