Revisiting TESLA in the quantum random oracle model, Post-Quantum Cryptography, vol.10346, pp.143-162, 2017. ,
Channel polarization: a method for constructing capacity-achieving codes for symmetric binary-input memoryless channels, IEEE Trans. Inform. Theory, vol.55, issue.7, pp.3051-3073, 2009. ,
, Complexity issues in coding theory. Electronic Colloquium on Computational Complexity, 1997.
Using LDGM codes and sparse syndromes to achieve digital signatures, Post-Quantum Cryptography, vol.7932, pp.1-15, 2013. ,
Mcbits: Fast constant-time code-based cryptography, Advances in CryptologyCRYPTO 2011-31st Annual Cryptology Conference, vol.8086, pp.1-20, 2011. ,
Decoding random binary linear codes in 2 n/20 : How 1 + 1 = 0 improves information set decoding, Advances in Cryptology-EUROCRYPT 2012, 2012. ,
One-time signature scheme from syndrome decoding over generic error-correcting codes, Journal of Systems and Software, vol.84, issue.2, pp.198-204, 2011. ,
On the inherent intractability of certain coding problems, IEEE Trans. Inform. Theory, vol.24, issue.3, pp.384-386, 1978. ,
The exact security of digital signatures-how to sign with rsa and rabin, Advances in Cryptology-EUROCRYPT '96, vol.1070, pp.399-416, 1996. ,
Tight security reduction in the quantum random oracle model for code-based signature schemes, 2017. ,
URL : https://hal.archives-ouvertes.fr/hal-01660693
How to achieve a McEliece-based digital signature scheme, Advances in Cryptology-ASIACRYPT, vol.2248, pp.157-174, 2001. ,
URL : https://hal.archives-ouvertes.fr/inria-00072511
Distinguisher-based attacks on public-key cryptosystems using Reed-Solomon codes, Des. Codes Cryptogr, vol.73, issue.2, pp.641-666, 2014. ,
Optimal security proofs for PSS and other signature schemes, Advances in Cryptology-EUROCRYPT 2002, International Conference on the Theory and Applications of Cryptographic Techniques, pp.272-287, 2002. ,
On Kabatianskii-Krouk-Smeets signatures, Arithmetic of Finite Fields-WAIFI 2007, vol.4547, pp.237-251, 2007. ,
URL : https://hal.archives-ouvertes.fr/hal-00259021
A new signature scheme based on (U |U + V ) codes. preprint, 2017. ,
The problem with the surf scheme, 2017. ,
, , 2017.
Two attacks on rank metric code-based schemes: Ranksign and an identity-based-encryption scheme, Advances in CryptologyASIACRYPT 2018, 2018. ,
On minimum distance decoding of linear codes, Proc. 5th Joint Soviet-Swedish Int. Workshop Inform. Theory, pp.50-52, 1991. ,
A distinguisher for high rate McEliece cryptosystems, Proc. IEEE Inf. Theory Workshop-ITW 2011, pp.282-286, 2011. ,
Falcon: Fast-fourier lattice ,
Parallel-CFS-strengthening the CFS McEliece-based signature scheme, Selected Areas in Cryptography 17th International Workshop, vol.6544, pp.159-170, 2010. ,
Security bounds for the design of code-based cryptosystems, Advances in Cryptology-ASIACRYPT 2009, vol.5912, pp.88-105, 2009. ,
Trapdoors for hard lattices and new cryptographic constructions, Proceedings of the fortieth annual ACM symposium on Theory of computing, pp.197-206, 2008. ,
New results for rank-based cryptography, Progress in Cryptology-AFRICACRYPT 2014, vol.8469, pp.1-12, 2014. ,
URL : https://hal.archives-ouvertes.fr/hal-01261421
Efficient code-based one-time signature from automorphism groups with syndrome compatibility, Proc. IEEE Int. Symposium Inf. TheoryISIT 2012, pp.1982-1986, 2012. ,
URL : https://hal.archives-ouvertes.fr/hal-00913728
McEliece in the world of Escher. IACR Cryptology ePrint Archive, 2014. ,
Official NIST comments made for RaCoSS, 2018. ,
Better algorithms for high-dimensional proximity problems via asymmetric embeddings, Proc. ACM-SIAM SODA, pp.539-545, 2003. ,
On the complexity of some cryptographic problems based on the general decoding problem, IEEE Trans. Inform. Theory, vol.48, issue.10, pp.2669-2678, 2002. ,
A digital signature scheme based on random error-correcting codes, IMA Int. Conf., volume 1355 of LNCS, pp.161-167, 1997. ,
Error Correcting Coding and Security for Data Networks: Analysis of the Superchannel Concept, 2005. ,
A new version of McEliece PKC based on convolutional codes, Information and Communications Security, vol.7168, pp.461-470, 2012. ,
Post quantum signature scheme based on modified Reed-Muller code pqsigRM. first round submission to the NIST postquantum cryptography call, 2017. ,
Implementing CFS, Progress in Cryptology-INDOCRYPT 2012, vol.7668, pp.474-488, 2012. ,
URL : https://hal.archives-ouvertes.fr/hal-00880644
An efficient attack of a McEliece cryptosystem variant based on convolutional codes, Post-Quantum Cryptography'13, vol.7932, pp.102-117, 2013. ,
URL : https://hal.archives-ouvertes.fr/hal-00880654
Using Reed-Solomon codes in the (u|u + v) construction and an application to cryptography, Proc. IEEE Int. Symposium Inf. TheoryISIT, pp.930-934, 2016. ,
Decoding random linear codes in O(2 0.054n ), Advances in Cryptology-ASIACRYPT 2011, vol.7073, pp.107-124, 2011. ,
On computing nearest neighbors with applications to decoding of binary linear codes, Advances in CryptologyEUROCRYPT 2015, vol.9056, pp.203-228, 2015. ,
Vulnerabilities of "McEliece in the World of Escher, Post-Quantum Cryptography 2016, 2016. ,
Knapsack-type cryptosystems and algebraic coding theory. Problems of Control and Information Theory, vol.15, pp.159-166, 1986. ,
An efficient attack on all concrete KKS proposals, Post-Quantum Cryptography, vol.7071, pp.98-116, 2011. ,
URL : https://hal.archives-ouvertes.fr/hal-00913500
Code-based cryptosystems using generalized concatenated codes, Applications of Computer Algebra, ACA 2015, vol.198, pp.397-423, 2017. ,
The use of information sets in decoding cyclic codes, IRE Transactions on Information Theory, vol.8, issue.5, pp.5-9, 1962. ,
An efficient attack on a code-based signature scheme, Post-Quantum Cryptography, vol.9606, pp.86-103, 2016. ,
URL : https://hal.archives-ouvertes.fr/hal-01289044
Decoding one out of many, Post-Quantum Cryptography, vol.7071, pp.51-67, 2011. ,
Sequences of games: a tool for taming complexity in security proofs, IACR Cryptology ePrint Archive, p.332, 2004. ,
Expander codes, IEEE Trans. Inform. Theory, vol.42, issue.6, pp.1710-1722, 1996. ,
A method for finding codewords of small weight, Coding Theory and Applications, vol.388, pp.106-113, 1988. ,
Approximating the number of error locations within a constant ratio is NPcomplete, LNCS, vol.673, pp.325-331, 1993. ,
A new identification scheme based on syndrome decoding, Advances in Cryptology-CRYPTO'93, vol.773, pp.13-21, 1993. ,
