, With Rank-1 Cuts (n, m, set, vol.40, p.1
Near-optimal solutions of large-scale single-machine scheduling problems, INFORMS Journal on Computing, vol.17, issue.2, pp.183-191, 2005. ,
New route relaxation and pricing strategies for the vehicle routing problem, Operations research, vol.59, issue.5, pp.1269-1283, 2011. ,
The time-dependent traveling salesman problem and single machine scheduling problems with sequence dependent setup times, Discrete Optimization, vol.5, issue.4, pp.685-699, 2008. ,
, , 0324.
A memetic algorithm to solve an unrelated parallel machine scheduling problem with auxiliary resources in semiconductor manufacturing, Journal of Scheduling, vol.19, issue.4, pp.367-376, 2016. ,
URL : https://hal.archives-ouvertes.fr/emse-01555622
An exact extended formulation for the unrelated parallel machine total weighted completion time problem, Journal of Scheduling, vol.20, issue.4, pp.373-389, 2017. ,
Solving parallel machine scheduling problems by column generation, INFORMS Journal on Computing, vol.11, issue.1, pp.78-94, 1999. ,
A new exact algorithm for the multi-depot vehicle routing problem under capacity and route length constraints, Discrete Optimization, vol.12, pp.129-146, 2014. ,
A branch-cut-and-price algorithm for the vehicle routing problem with stochastic demands, Computers & Operations Research, vol.50, pp.141-153, 2014. ,
Discrete Optimization II Proceedings of the Advanced Research Institute on Discrete Optimization and Systems Applications of the Systems Science Panel of NATO and of the Discrete Optimization Symposium co-sponsored by IBM Canada and SIAM Banff, Annals of Discrete Mathematics, vol.5, pp.287-326, 1979. ,
A dynamic programming algorithm for the shortest path problem with time windows and linear node costs, Networks, vol.31, issue.3, pp.193-204, 1998. ,
Subset-row inequalities applied to the vehicle-routing problem with time windows, Operations Research, vol.56, issue.2, pp.497-511, 2008. ,
A branch-and-cut algorithm for the symmetric twoechelon capacitated vehicle routing problem, Transportation Science, vol.47, issue.1, pp.23-37, 2013. ,
Dominance rules for the parallel machine total weighted tardiness scheduling problem with release dates, Computers & Operations Research, vol.38, issue.9, pp.1259-1266, 2011. ,
URL : https://hal.archives-ouvertes.fr/hal-00943855
A branch-and-price algorithm for parallel machine scheduling using zdds and generic branching, INFORMS Journal on Computing Forthcoming, 2018. ,
Um método heurístico para a resolução de uma classe de problemas de sequenciamento da produção envolvendo penalidades por antecipação e atraso, 2015. ,
A unified heuristic and an annotated bibliography for a large class of earliness-tardiness scheduling problems, Journal of Scheduling First Online Cadernos, 2017. ,
Complexity of machine scheduling problems, Studies in Integer Programming, vol.1, pp.343-362, 1977. ,
Scheduling unrelated parallel machines to minimize total weighted tardiness, Computers & Operations Research, vol.30, issue.12, pp.1777-1789, 2003. ,
A branch-and-bound algorithm to minimize total weighted completion time on identical parallel machines with job release dates, Computers & Operations Research, vol.35, issue.4, pp.1176-1190, 2008. ,
An improved branch-cut-and-price algorithm for parallel machine scheduling problems, INFORMS Journal on Computing Forthcoming, 2018. ,
New hybrid optimization algorithms for machine scheduling problems, IEEE Transactions on Automation Science and Engineering, vol.5, issue.2, pp.337-348, 2008. ,
New enhancements for the exact solution of the vehicle routing problem with time windows, INFORMS Journal on Computing, vol.29, issue.3, pp.489-502, 2017. ,
Improved branch-cut-and-price for capacitated vehicle routing, Mathematical Programming Computation, vol.9, issue.1, pp.61-100, 2017. ,
A branch-and-price algorithm for scheduling parallel machines with sequence dependent setup times, European Journal of Operational Research, vol.176, issue.3, pp.1508-1527, 2007. ,
Exact algorithm over an arc-time-indexed formulation for parallel machine scheduling problems, Mathematical Programming Computation, vol.2, issue.3-4, pp.259-290, 2010. ,
Automation and combination of linearprogramming based stabilization techniques in column generation, INFORMS Journal on Computing, vol.30, issue.2, pp.339-360, 2018. ,
URL : https://hal.archives-ouvertes.fr/hal-01077984
Integer program reformulation for robust branch-and-cutand-price, Annals of Mathematical Programming in Rio, pp.56-61, 2003. ,
Symmetry helps: Bounded bi-directional dynamic programming for the elementary shortest path problem with resource constraints, Discrete Optimization, vol.3, issue.3, pp.255-273, 2006. ,
, , 0326.
Branching decisions in branch-and-cut-and-price algorithms for vehicle routing problems, 2012. ,
Minimizing total tardiness for scheduling identical parallel machines with family setups, Computers & Industrial Engineering, vol.72, issue.0, pp.274-281, 2014. ,
A strong preemptive relaxation for weighted tardiness and earliness/tardiness problems on unrelated parallel machines, INFORMS Journal on Computing, vol.27, issue.1, pp.135-150, 2015. ,
Minimizing total tardiness in an unrelated parallel-machine scheduling problem, Journal of the Operational Research Society, vol.58, issue.3, pp.346-354, 2007. ,
Scheduling on parallel identical machines to minimize total tardiness, European Journal of Operational Research, vol.177, issue.1, pp.135-146, 2007. ,
Earliness-tardiness scheduling with setup considerations, Computers & Operations Research, vol.32, issue.7, pp.1849-1865, 2005. ,
URL : https://hal.archives-ouvertes.fr/hal-01185226
The one-machine problem with earliness and tardiness penalties, Journal of Scheduling, vol.6, issue.6, pp.533-549, 2003. ,
A faster branch-and-bound algorithm for the earliness-tardiness scheduling problem, Journal of Scheduling, vol.11, issue.1, pp.49-58, 2008. ,
URL : https://hal.archives-ouvertes.fr/hal-01185214
A branch-and-bound algorithm with lagrangian relaxation to minimize total tardiness on identical parallel machines, International Journal of Production Economics, vol.113, issue.1, pp.446-458, 2008. ,
An exact algorithm for the single-machine total weighted tardiness problem with sequence-dependent setup times, Computers & Operations Research, vol.40, issue.1, pp.344-352, 2013. ,
An efficient exact algorithm for general single-machine scheduling with machine idle time, Automation Science and Engineering, pp.371-376, 2008. ,
A dynamic-programming-based exact algorithm for general singlemachine scheduling with machine idle time, Journal of Scheduling, vol.15, issue.3, pp.347-361, 2012. ,
An exact algorithm for single-machine scheduling without machine idle time, Journal of Scheduling, vol.12, issue.6, pp.575-593, 2009. ,
Time-indexed formulations for machine scheduling problems: Column generation, INFORMS Journal on Computing, vol.12, issue.2, pp.111-124, 2000. ,
, , 0327.
New exact method to solve the P m |r j | C j schedule problem, International Journal of Production Economics, vol.100, issue.1, pp.168-179, 2006. ,
