Min-max and min-max regret versions of combinatorial optimization problems: A survey, European Journal of Operational Research, vol.197, issue.2, pp.427-438, 2009. ,
URL : https://hal.archives-ouvertes.fr/hal-00158652
A note on the bertsimas & sim algorithm for robust combinatorial optimization problems, 4OR, vol.11, issue.4, pp.349-360, 2013. ,
An exact algorithm for the vehicle routing problem based on the set partitioning formulation with additional cuts, Mathematical Programming, vol.115, pp.351-385, 2008. ,
A unified exact method for solving different classes of vehicle routing problems, Mathematical Programming, vol.120, issue.2, pp.347-380, 2009. ,
New route relaxation and pricing strategies for the vehicle routing problem, Operations Research, vol.59, issue.5, pp.1269-1283, 2011. ,
, , 2009.
Adjustable robust solutions of uncertain linear programs, Mathematical Programming, vol.99, issue.2, pp.351-376, 2004. ,
Robust convex optimization, Mathematics of Operations Research, vol.23, issue.4, pp.769-805, 1998. ,
Robust discrete optimization and network flows, Mathematical Programming, vol.98, issue.1-3, pp.49-71, 2003. ,
The price of robustness, Operations Research, vol.52, issue.1, pp.35-53, 2004. ,
Introduction to Stochastic programming, 2011. ,
A branch-and-price algorithm for the minimum latency problem, Computers & Operations Research, vol.93, pp.66-78, 2018. ,
URL : https://hal.archives-ouvertes.fr/hal-01664835
Lower bounds and algorithms for the 2-dimensional vector packing problem, Discrete Applied Mathematics, vol.111, issue.3, pp.231-262, 2001. ,
Exact algorithms for the chance-constrained vehicle routing problem, Mathematical Programming, vol.172, issue.1, pp.105-138, 2018. ,
Robust branch-andcut-and-price for the capacitated vehicle routing problem, Mathematical Programming, vol.106, issue.3, pp.491-511, 2006. ,
Stochastic vehicle routing, European Journal of Operational Research, vol.88, issue.1, pp.3-12, 1996. ,
The distributionally robust chance constrained vehicle routing problem, 2019. ,
An adaptive memory programming framework for the robust capacitated vehicle routing problem, Tranportaion Science, vol.50, issue.4, pp.1239-1260, 2016. ,
The robust capacitated vehicle routing problem under demand uncertainty, Operations Research, vol.61, issue.3, pp.677-693, 2013. ,
A heuristic for moment-matching scenario generation, Computational Optimization and Applications, vol.24, issue.2, pp.169-185, 2003. ,
Shortest Path Problems with Resource Constraints, pp.33-65, 2005. ,
Path-reduced costs for eliminating arcs in routing and scheduling, INFORMS Journal on Computing, vol.22, issue.2, pp.297-313, 2010. ,
Branch-cut-and-price for vehicle routing problem with demand uncertainty ec22 e-companion to Pessoa et al.: Branch-cut-and-price for vehicle routing problem with demand uncertainty ec24 e-companion to Pessoa et al.: Branch-cut-and-price for vehicle routing problem with demand uncertainty ,
, B-n66-k9 1249, vol.2, pp.1251-1298
, A-n33-k5 630.7 642 2.65 B-n67-k10 1006, vol.0, p.1007
, B-n68-k9 1204, vol.1, pp.1205-1229
, A-n34-k5 708.8 715 0.60 B-n78-k10 1130, vol.3, p.1131
, A-n54-k7 1105.5 1106 7.70 F-n45-k4
, A-n60-k9 1276.2 1280 4.65 F-n135-k7 1111, vol.8, p.1122
, A-n61-k9 978.4 983 5.28 M-n101-k10
UB avg t. min t. max t. Inst. UB avg t ,
, A-n60-k9 1404.1 1408 176.50 F-n45-k4
, A-n63-k10 1348.0 1348 56.41 P-n19-k2
