Precised approximations in elliptic homogenization beyond the periodic setting - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Asymptotic Analysis Année : 2020
Xavier Blanc
Marc Josien
We consider homogenization problems for linear elliptic equations in divergence form. The coecients are assumed to be a local perturbation of some periodic background. We prove $W^{1,p}$ and Lipschitz convergence of the two-scale expansion, with explicit rates. For this purpose, we use a corrector adapted to this particular setting, and dened in [10, 11], and apply the same strategy of proof as Avellaneda and Lin in [1]. We also propose an abstract setting generalizing our particular assumptions for which the same estimates hold.
article.pdf (517.91 Ko) Télécharger le fichier
hal-01958207 , version 1 (17-12-2018)
Xavier Blanc, Marc Josien, Claude Le Bris. Precised approximations in elliptic homogenization beyond the periodic setting. Asymptotic Analysis, 2020, 116 (2), pp.93-137. ⟨10.3233/ASY-191537⟩. ⟨hal-01958207⟩
276 Consultations
191 Téléchargements
