Categorical data analysis. A Wiley-Interscience publication, 1990. ,
Convergent Stochastic Expectation Maximization algorithm with efficient sampling in high dimension, Application to deformable template model estimation, 2013. ,
URL : https://hal.archives-ouvertes.fr/hal-01606162
On the ergodicity properties of some adaptive mcmc algorithms, Wiley Reference Series in Biostatistics. Andrieu, vol.16, pp.1462-1505, 2006. ,
A tutorial on adaptive mcmc, Statistics and computing, vol.18, pp.343-373, 2008. ,
On adaptive Markov chain Monte Carlo algorithms, Bernoulli, vol.11, pp.815-828, 2005. ,
The NONMEM system, The American Statistician, vol.34, pp.118-119, 1980. ,
A conceptual introduction to Hamiltonian Monte Carlo, 2017. ,
Handbook of markov chain monte carlo, 2011. ,
, The tamed unadjusted langevin algorithm, 2017.
URL : https://hal.archives-ouvertes.fr/hal-01648667
Stan: A probabilistic programming language, Journal of Statistical Software, vol.76, 2017. ,
The use of the SAEM algorithm in MONOLIX software for estimation of population pharmacokinetic-pharmacodynamicviral dynamics parameters of maraviroc in asymptomatic HIV subjects, Journal of Pharmacokinetics and Pharmacodynamics, vol.38, pp.41-61, 2011. ,
Parameter estimation in nonlinear mixed effect models using saemix, an r implementation of the saem algorithm, Journal of Statistical Software, vol.80, pp.1-42, 2017. ,
URL : https://hal.archives-ouvertes.fr/hal-01672496
Convergence of a stochastic approximation version of the EM algorithm, Ann. Statist, vol.27, pp.94-128, 1999. ,
Fast langevin based algorithm for mcmc in high dimensions, Ann. Appl. Probab, vol.27, pp.2195-2237, 2017. ,
URL : https://hal.archives-ouvertes.fr/hal-01174226
Variational mcmc, Proceedings of the Seventeenth Conference on Uncertainty in Artificial Intelligence, pp.120-127, 2001. ,
Riemann manifold langevin and hamiltonian monte carlo methods, Journal of the Royal Statistical Society: Series B (Statistical Methodology), vol.73, pp.123-214, 2011. ,
Evaluating derivatives: principles and techniques of algorithmic differentiation, vol.105, 2008. ,
An adaptive metropolis algorithm, Bernoulli, vol.7, pp.223-242, 2001. ,
The No-U-turn sampler: adaptively setting path lengths in Hamiltonian Monte Carlo, Journal of Machine Learning Research, vol.15, pp.1593-1623, 2014. ,
Automatic variational inference in stan, Advances in Neural Information Processing Systems 28, pp.568-576, 2015. ,
Coupling a stochastic approximation version of EM with an MCMC procedure, ESAIM: Probability and Statistics, vol.8, pp.115-131, 2004. ,
Mixed effects models for the population approach: models, tasks, methods and tools, 2014. ,
URL : https://hal.archives-ouvertes.fr/hal-01122873
Enhanced method for diagnosing pharmacometric models: random sampling from conditional distributions, Pharmaceutical research, vol.33, pp.2979-2988, 2016. ,
URL : https://hal.archives-ouvertes.fr/hal-01365532
Finding the observed information matrix when using the em algorithm, Journal of the Royal Statistical Society, Series B: Methodological, vol.44, pp.226-233, 1982. ,
Joint modeling of longitudinal and repeated time-toevent data using nonlinear mixed-effects models and the SAEM algorithm, Journal of Statistical Computation and Simulation, vol.85, pp.1512-1528, 2015. ,
The EM algorithm and extensions, vol.382, 2007. ,
Rates of convergence of the hastings and metropolis algorithms, Ann. Statist, vol.24, pp.101-121, 1996. ,
Equation of state calculations by fast computing machines, The Journal of Chemical Physics, vol.21, pp.1087-1092, 1953. ,
Statistical Inference: An Integrated Approach, Second Edition. Chapman & Hall/CRC Texts in Statistical Science, 2014. ,
Mcmc using hamiltonian dynamics. Handbook of Markov Chain Monte Carlo 2, 2, 2011. ,
Studies on coumarin anticoagulant drugs initiation of warfarin therapy without a loading dose, Circulation, vol.38, pp.169-177, 1968. ,
Madness: a package for multivariate automatic differentiation, 2016. ,
Metropolis-Hastings Algorithms, pp.167-197, 2010. ,
URL : https://hal.archives-ouvertes.fr/hal-01067920
Weak convergence and optimal scaling of random walk metropolis algorithms, Ann. Appl. Probab, vol.7, pp.110-120, 1997. ,
Optimal scaling of discrete approximations to langevin diffusions, J. R. Statist. Soc. B, vol.60, pp.255-268, 1997. ,
Quantitative non-geometric convergence bounds for independence samplers, Methodology and Computing in Applied Probability, vol.13, pp.391-403, 2011. ,
Exponential convergence of langevin distributions and their discrete approximations, Bernoulli, vol.2, pp.341-363, 1996. ,
Approximate bayesian inference for latent gaussian models by using integrated nested laplace approximations, Journal of the royal statistical society: Series b (statistical methodology), vol.71, pp.319-392, 2009. ,
Implementation and evaluation of the SAEM algorithm for longitudinal ordered categorical data with an illustration in pharmacokinetics-pharmacodynamics, The AAPS Journal, vol.13, pp.44-53, 2011. ,
URL : https://hal.archives-ouvertes.fr/hal-00637400
RStan: the R interface to Stan, 2018. ,
Langevin-type models i: Diffusions with given stationary distributions and their discretizations*, Methodology And Computing In Applied Probability, vol.1, pp.283-306, 1999. ,
Auxiliary gradient-based sampling algorithms, Journal of the Royal Statistical Society: Series B (Statistical Methodology), p.0, 2018. ,
Linear mixed models for longitudinal data, 1997. ,
Robust adaptive metropolis algorithm with coerced acceptance rate, Statistics and Computing, vol.22, pp.997-1008, 2012. ,
Parametric regression model for survival data: Weibull regression model as an example, Ann Transl Med, vol.24, 2016. ,
