New interface
Conference papers
Analyzing LoRa long-range, low-power, wide-area networks using stochastic geometry
Bartłomiej Błaszczyszyn 1 Paul Mühlethaler 2
1 DYOGENE - Dynamics of Geometric Networks
DI-ENS - Département d'informatique - ENS Paris, CNRS - Centre National de la Recherche Scientifique : UMR 8548, Inria de Paris
Abstract : In this paper we present a simple, stochastic-geometric model of a wireless access network exploiting the LoRA (Long Range) protocol, which is a non-expensive technology allowing for long-range, single-hop connectivity for the Internet of Things. We assume a space-time Poisson model of packets transmitted by LoRA nodes to a fixed base station. Following previous studies of the impact of interference, we assume that a given packet is successfully received when no interfering packet arrives with similar power before the given packet payload phase. This is as a consequence of LoRa using different transmission rates for different link budgets (transmissions with smaller received powers use larger spreading factors) and LoRa intra-technology interference treatment. Using our model, we study the scaling of the packet reception probabilities per link budget as a function of the spatial density of nodes and their rate of transmissions. We consider both the parameter values recommended by the LoRa provider, as well as proposing LoRa tuning to improve the equality of performance for all link budgets. We also consider spatially non-homogeneous distributions of LoRa nodes. We show also how a fair comparison to non-slotted Aloha can be made within the same framework.
Complete list of metadata
https://hal.inria.fr/hal-01958939
Contributor : Bartlomiej Blaszczyszyn Connect in order to contact the contributor
Submitted on : Tuesday, December 18, 2018 - 1:02:35 PM
Last modification on : Tuesday, October 25, 2022 - 4:23:55 PM
Links full text
Identifiers
Collections
Citation
Bartłomiej Błaszczyszyn, Paul Mühlethaler. Analyzing LoRa long-range, low-power, wide-area networks using stochastic geometry. VALUETOOLS 2019 - 12th EAI International Conference on Performance Evaluation Methodologies and Tools, ACM, Mar 2019, Palma de Mallorca, Spain. ⟨10.1145/3306309.3306327⟩. ⟨hal-01958939⟩
Share
Metrics
Record views
117
