Detailed Land Cover Mapping from Multitemporal Landsat-8 Data of Different Cloud Cover
Detailed, accurate and frequent land cover mapping is a prerequisite for several important geospatial applications and the fulfilment of current sustainable development goals. This paper introduces a methodology for the classification of annual high-resolution satellite data into several detailed land cover classes. In particular, a nomenclature with 27 different classes was introduced based on CORINE Land Cover (CLC) Level-3 categories and further analysing various crop types. Without employing cloud masks and/or interpolation procedures, we formed experimental datasets of Landsat-8 (L8) images with gradually increased cloud cover in order to assess the influence of cloud presence on the reference data and the resulting classification accuracy. The performance of shallow kernel-based and deep patch-based machine learning classification frameworks was evaluated. Quantitatively, the resulting overall accuracy rates differed within a range of less than 3%; however, maps produced based on Support Vector Machines (SVM) were more accurate across class boundaries and the respective framework was less computationally expensive compared to the applied patch-based deep Convolutional Neural Network (CNN). Further experimental results and analysis indicated that employing all multitemporal images with up to 30% cloud cover delivered relatively higher overall accuracy rates as well as the highest per-class accuracy rates. Moreover, by selecting 70% of the top-ranked features after applying a feature selection strategy, slightly higher accuracy rates were achieved. A detailed discussion of the quantitative and qualitative evaluation outcomes further elaborates on the performance of all considered classes and highlights different aspects of their spectral behaviour and separability.
