Exploring to learn visual saliency: The RL-IAC approach - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Robotics and Autonomous Systems Année : 2019
The problem of object localization and recognition on autonomous mobile robots is still an active topic. In this context, we tackle the problem of learning a model of visual saliency directly on a robot. This model, learned and improved on-the-fly during the robot's exploration provides an efficient tool for localizing relevant objects within their environment. The proposed approach includes two intertwined components. On the one hand, we describe a method for learning and incrementally updating a model of visual saliency from a depth-based object detector. This model of saliency can also be exploited to produce bounding box proposals around objects of interest. On the other hand, we investigate an autonomous exploration technique to efficiently learn such a saliency model. The proposed exploration, called Reinforcement Learning-Intelligent Adaptive Curiosity (RL-IAC) is able to drive the robot's exploration so that samples selected by the robot are likely to improve the current model of saliency. We then demonstrate that such a saliency model learned directly on a robot outperforms several state-of-the-art saliency techniques, and that RL-IAC can drastically decrease the required time for learning a reliable saliency model.
Exploring_to_learn_visual_saliency_The_RL_IAC_approach.pdf (4.35 Mo) Télécharger le fichier
hal-01959882 , version 1 (19-12-2018)
Céline Craye, Timothée Lesort, David Filliat, Jean-François Goudou. Exploring to learn visual saliency: The RL-IAC approach. Robotics and Autonomous Systems, 2019, 112, pp.244-259. ⟨10.1016/j.robot.2018.11.012⟩. ⟨hal-01959882⟩
142 Consultations
107 Téléchargements
