Towards Open Data Quality Improvements Based on Root Cause Analysis of Quality Issues - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2018
Csaba Csáki
  • Fonction : Auteur
  • PersonId : 1040869
Commercial reuse of open government data in value added services has gained a lot of interest both as practice and as a research topic over the last few years. However, utilizing open data without proper understanding of potential quality issues carries the risk of undermining the value of the service that relies on public sector information. Instead of establishing a data quality assessment framework this research considers a review of typical open data quality issues and intends to connect them to the causes leading to these various data problems. Open data specific problems are concluded from a case study and then theoretical and empirical arguments are used to connect them to root causes emerging from the peculiarities of the public sector data management process. This way both practitioners could be more conscious about appropriate cleansing methods and participants shaping the data management process could aim at eliminating root causes of data quality issues.
472235_1_En_18_Chapter.pdf (251.79 Ko) Télécharger le fichier
hal-01961523 , version 1 (20-12-2018)
Paternité
Csaba Csáki. Towards Open Data Quality Improvements Based on Root Cause Analysis of Quality Issues. 17th International Conference on Electronic Government (EGOV), Sep 2018, Krems, Austria. pp.208-220, ⟨10.1007/978-3-319-98690-6_18⟩. ⟨hal-01961523⟩
104 Consultations
79 Téléchargements
