A non-local algorithm for image denoising, Comput. Vis. Pattern Recognit, vol.2, pp.60-65, 2005. ,
Compressed sensing image reconstruction via recursive spatially adaptive filtering, Int. Conf. Image Process, vol.1, pp.549-552, 2007. ,
DOI : 10.1109/icip.2007.4379013
Structure determination In Situ by averaging of tomograms, Cell. Electron Microsc, vol.79, pp.741-767, 2007. ,
, Experimental sub-tomogram (61 × 61 × 61 voxels) containing a gold particle (dataset B). The top row shows the input in the spectral and spatial domains, the bottom row shows the output
Single versus dual-axis cryo-electron tomography of microtubules assembled in vitro: limits and perspectives, J. Struct. Biol, vol.181, issue.2, pp.169-78, 2013. ,
URL : https://hal.archives-ouvertes.fr/inserm-00831759
PEWA: Patch-based exponentially weighted aggregation for image denoising, Adv. Neural Inf. Process. Syst, vol.27, pp.1-9, 2014. ,
URL : https://hal.archives-ouvertes.fr/hal-01103358
A simple Fourier filter for suppression of the missing wedge ray artefacts in single-axis electron tomographic reconstructions, J. Struct. Biol, vol.186, issue.1, pp.141-52, 2014. ,
Compressed sensing electron tomography, Ultramicroscopy, vol.131, pp.70-91, 2013. ,
A nonlocal Bayesian image denoising algorithm, SIAM J. Imaging Sci, vol.6, issue.3, pp.1665-1688, 2013. ,
Nonlocal transform-domain filter for volumetric data denoising and reconstruction, IEEE Trans. Image Process, vol.22, issue.1, pp.119-133, 2013. ,
Compensation of missing wedge effects with sequential statistical reconstruction in electron tomography, PLoS One, vol.9, issue.10, pp.1-23, 2014. ,
Fourier shell correlation threshold criteria, J. Struct. Biol, vol.151, pp.250-262, 2005. ,
, The method flowchart. The 1 st icon row represents the data in the spectral domain, the 2 nd in the spatial domain
