Minimum time control of heterodirectional linear coupled hyperbolic pdes, Automatica, vol.71, pp.300-307, 2016. ,
URL : https://hal.archives-ouvertes.fr/hal-01215600
Boundary control of coupled reaction-diffusion processes with constant parameters, Automatica, vol.54, pp.80-90, 2015. ,
Finite time stability of continuous autonomous systems, SIAM J. Control Optim, vol.38, issue.3, pp.751-766, 2000. ,
Boundary control of an unstable heat equation via measurement of domain-averaged temperature. Automatic Control, IEEE Transactions on, vol.46, issue.12, pp.2022-2028, 2001. ,
The solution of initial-boundary value problems for parabolic equations by the method of integral operators, Journal of Differential Equations, vol.26, issue.2, pp.181-190, 1977. ,
Finite-time boundary stabilization of general linear hyperbolic balance laws via fredholm backstepping transformation, Automatica, vol.84, pp.95-100, 2017. ,
URL : https://hal.archives-ouvertes.fr/hal-01437107
Null controllability and finite time stabilization for the heat equations with variable coefficients in space in one dimension via backstepping approach, Archive for Rational Mechanics and Analysis, vol.225, issue.3, pp.993-1023, 2017. ,
URL : https://hal.archives-ouvertes.fr/hal-01228895
Backstepping control of coupled linear parabolic PIDEs with spatially-varying coefficients, IEEE Transactions on Automatic Control, issue.99, pp.1-1, 2018. ,
On continuous boundary time-varying feedbacks for fixed-time stabilization of coupled reaction-diffusion systems, 57th IEEE Conference on Decision and Control, 2018. ,
URL : https://hal.archives-ouvertes.fr/hal-01892409
Necessary and sufficient conditions for complete blow-up and extinction for onedimensional quasilinear heat equation. Archive for Rational Mechanics and Analysis, vol.129, pp.225-244, 1995. ,
Finite time controllers, SIAM Journal of Control and Optimization, vol.24, issue.4, pp.760-770, 1986. ,
Finite-time and fixed-time observer design: Implicit lyapunov function approach, Automatica, vol.87, pp.52-60, 2018. ,
URL : https://hal.archives-ouvertes.fr/hal-01622356
Finite-time multi-agent deployment: A nonlinear PDE motion planning approach, Automatica, vol.47, issue.11, pp.2534-2542, 2011. ,
Tracking control for boundary controlled parabolic PDEs with varying parameters: Combining backstepping and differential flatness, Automatica, vol.45, issue.5, pp.1182-1194, 2009. ,
A new bound for the Laguerre polynomials, 5th Int. Symp. on Orthogonal Polynomials, Special Functions and t heir Applications, vol.133, pp.489-493, 2001. ,
Theory of optimal systems with generalized controls (in Russian), 1988. ,
Schwartz' distributions in nonlinear setting: Applications to differential equations, filtering and optimal control, Mathematical Problems in Engineering, vol.8, issue.4-5, pp.367-387, 2002. ,
Discontinuous systems: Lyapunov analysis and robust synthesis under uncertainty conditions, 2009. ,
Output feedback stabilization of coupled reaction-diffusion processes with constant parameters, SIAM Journal on Control and Optimization, vol.55, issue.6, pp.4112-4155, 2017. ,
Semigroups of Linear Operators and Applications to Partial Differential Equations, 1983. ,
Finite-time stabilization of 2 × 2 hyperbolic systems on tree-shaped networks, SIAM Journal on Control and Optimization, vol.52, issue.1, pp.143-163, 2014. ,
URL : https://hal.archives-ouvertes.fr/hal-00793728
On the ISS properties of a class of parabolic DPS' with discontinuous control using sampled-inspace sensing and actuation, Automatica, vol.81, pp.447-454, 2017. ,
Tracking control of the uncertain heat and wave equation via power-fractional and sliding-mode techniques, SIAM Journal on Control and Optimization, vol.49, issue.2, pp.363-382, 2011. ,
Handbook of linear partial differential equations for engineers and scientists, 2002. ,
On boundary finitetime feedback control for heat equation, 20th IFAC World Congress, 2017. ,
URL : https://hal.archives-ouvertes.fr/hal-01505482
On Homogeneous Finite-Time Control For Evolution Equation in Hilbert Space, IEEE Transactions on Automatic Control, pp.1-1, 2017. ,
URL : https://hal.archives-ouvertes.fr/hal-01695475
, Finite-time and Fixed-time Stabilization: Implicit Lyapunov Function Approach, vol.51, pp.332-340, 2015.
URL : https://hal.archives-ouvertes.fr/hal-01098099
Closed-form boundary state feedbacks for a class of 1-d partial integro-differential equations, IEEE Transactions on Automatic Control, vol.49, issue.12, pp.2185-2202, 2004. ,
On control design for pdes with space-dependent diffusivity or time-dependent reactivity, Automatica, vol.41, issue.9, pp.1601-1608, 2005. ,
Timevarying feedback for regulation of normal-form nonlinear systems in prescribed finite time, Automatica, vol.83, pp.243-251, 2017. ,
Timevarying feedback for stabilization in prescribed finite time, International Journal of Robust and Nonlinear Control, 2018. ,
Orthogonal polynomials, vol.23, 1975. ,
Boundary control of coupled reaction-advection-diffusion systems with spatially-varying coefficients, IEEE Transactions on Automatic Control, vol.62, issue.4, pp.2026-2033, 2017. ,
Control for fast and stable laminar-to-high-reynolds-numbers transfer in a 2D Navier-Stokes channel flow, Discrete & Continuous Dynamical Systems-B, vol.10, issue.4, pp.925-956, 2008. ,
URL : https://hal.archives-ouvertes.fr/hal-00131057
