Curve Reconstruction via a Ribbon of Sensors, 14th IEEE Int. Conf. on Electronics, Circuits and Systems, pp.407-417, 2007. ,
URL : https://hal.archives-ouvertes.fr/hal-00872494
3D Shape Measuring Sheet Utilizing Gravitationa and Geomagnetic Fields, SICE Annual Conf, pp.915-935, 2008. ,
Surfaces Reconstruction Via Inertial Sensors for Monitoring, 7th European Workshop on Structural Health Monitoring, pp.702-711, 2014. ,
URL : https://hal.archives-ouvertes.fr/hal-01020418
New Generation of Flexible Risers Equipped with Motion Capture-Morphopipe System, Proc. EWSHM-8th European Workshop on Structural Health Monitoring, 2016. ,
Survey of nonlinear attitude estimation methods, J. Guid. Control Dyn, vol.30, pp.12-28, 2007. ,
Calibration methods for inertial and magnetic sensors, Sensors and Actuators A: Physical, vol.156, pp.302-311, 2009. ,
Differential Geometry of Curves and Surfaces, 1976. ,
A discrete regression method on manifolds and its application to data on, Proc. 18th IFAC WC, pp.2284-2289, 2011. ,
Interpolation and Regression of Rotation Matrices, Geom.Sci.Inf, pp.345-352, 2013. ,
ROPTLIB: An object-orient. C++ lib. for optim. On Riemannian manifolds, 2016. ,
A General and Efficient Method for Finding Cycles in 3D Curve Networks, ACM Trans Graph (Proc SIGGRAPH Asia), vol.32, issue.6, 2013. ,
Triangle: Engineering a 2D Quality Mesh Generator and Delaunay Triangulator, Applied computational geometry towards geometric engineering, pp.203-225, 1996. ,
An Algorithm for Triangulating Multiple 3D Polygons, Computer Graphics Forum (SGP), vol.32, issue.5, pp.157-66, 2013. ,
On Linear Variational Surface Deformation Methods, IEEE Trans Vis Comput Graphics, vol.14, issue.1, pp.213-243, 2008. ,
Discrete Differential Geometry Operators for Triangulated 2-manifolds, Visualization and mathematics III, pp.35-57, 2003. ,
Polygon Mesh Processing, 2010. ,
URL : https://hal.archives-ouvertes.fr/inria-00538098
Curvatures of Smooth and Discrete Surfaces, Discrete Differential Geometry; Oberwolfach Seminars, vol.38, pp.175-88, 2008. ,
