Don't Interrupt Me When You Reconfigure my Service Function Chains - Archive ouverte HAL Access content directly
Reports (Research Report) Year : 2018
N'interrompez pas mes Chaines de Service Lorsque Je les Reconfigure
(1, 2) , (2, 1) , (1, 3, 2) , (1, 2, 4)
1
2
3
4
Network Functions Virtualization (NFV) enables the complete decoupling of network functions from proprietary appliances and runs them as software applications on general–purpose servers. NFV allows network operators to dynamically deploy Virtual Network Functions (VNFs). Software Defined Networking (SDN) introduces a logically centralized controller which maintains a global view of the network state. The centralized routing model of SDN jointly with the possibility of instantiating VNFs on–demand open the way for a more efficient operation and management of networks. In this paper, we consider the problem of reconfiguring network connections with the goal of bringing the network from a sub-optimal to an optimal operational state. We propose optimization models based on the make-before-break mechanism, in which a new path is set up before the old one is torn down. Our method takes into consideration the chaining requirements of the flows and scales well with the number of nodes in the network. We show that, with our approach, the network operational cost defined in terms of both bandwidth and installed network function costs can be reduced and a higher acceptance rate can be achieved
La virtualisation des fonctions réseau (NFV) permet le découplage complet des fonctions réseau des appareils propriétaires et leur exécution en tant qu’applications logicielles. NFV permet aux opérateurs de réseaux de déployer dynamiquement des fonctions de réseau virtuel (VNF). Le Software Defined Networking (SDN) introduit un contrôleur centralisé qui maintient une vue globale de l’état du réseau. Le modèle de routage centralisé du SDN et la possibilité d’instancier les VNF à la demande ouvrent la voie à une exploitation et une gestion plus efficaces des réseaux. Dans cet article, nous examinons le problème de la reconfiguration des connexions réseau dans le but de faire passer le réseau d’un état sous-optimal à un état opérationnel optimal. Nous proposons des modèles d’optimisation basés sur le mécanisme make-before-break, dans lequel un nouveau chemin est mis en place avant que l’ancien ne soit détruit. Ceci permet de ne pas avoir d’interruption du trafic. Notre méthode prend en compte les exigences de chaînage des flux et s’adapte bien au nombre de nœuds du réseau. Nous montrons qu’avec notre approche, le coût d’exploitation du réseau défini en termes de bande passante et de coûts des NFV installées peut être réduit tout en augmentant le taux d’acceptation des requêtes.
RR-9241.pdf (2.33 Mo) Télécharger le fichier
Dates and versions
hal-01963270 , version 1 (21-12-2018)
hal-01963270 , version 2 (19-03-2019)
Identifiers
  • HAL Id : hal-01963270 , version 2
Cite
Adrien Gausseran, Andrea Tomassilli, Frédéric Giroire, Joanna Moulierac. Don't Interrupt Me When You Reconfigure my Service Function Chains. [Research Report] RR-9241, UCA, Inria; Université de Nice Sophia-Antipolis (UNS); CNRS; UCA,I3S. 2018. ⟨hal-01963270v2⟩
241 View
360 Download
Share
