Multi-source Relations for Contextual Data Mining in Learning Analytics - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2018
Julie Bu Daher
Armelle Brun
Anne Boyer
Track Academic research: comprehensive evaluations of recent innovations in learning and student analytics approaches. Context and Purpose The goals of Learning Analytics (LA) are manifold, among which helping students to understand their academic progress and improving their learning process, which are at the core of our work. To reach this goal, LA relies on educational data: students' traces of activities on VLE, or academic, socio-demographic information, information about teachers, pedagogical resources, curricula, etc. The data sources that contain such information are multiple and diverse. Data mining, specifically pattern mining, aims at extracting valuable and understandable information from large datasets [2]. In our work, we assume that multiple educational data sources form a rich dataset that can result in valuable patterns. Mining such data is thus a promising way to reach the goal of helping students. However, heterogeneity and interdependency within data lead to a high computational complexity. We thus aim at designing low complex pattern mining algorithms that mine multi-source data, taking into consideration the dependency and heterogeneity among sources. The patterns formed are meaningful and interpretable, they can thus be directly used for students.
LSAC_BUDAHER.pdf (66.96 Ko) Télécharger le fichier
hal-01963812 , version 1 (21-12-2018)
  • HAL Id : hal-01963812 , version 1
Julie Bu Daher, Armelle Brun, Anne Boyer. Multi-source Relations for Contextual Data Mining in Learning Analytics. LSAC Learning and Student Analytics Conference, Oct 2018, Amsterdam, Netherlands. ⟨hal-01963812⟩
117 Consultations
90 Téléchargements
