Dependence properties and Bayesian inference for asymmetric multivariate copulas - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Journal of Multivariate Analysis Année : 2019
We study a broad class of asymmetric copulas introduced by Liebscher (2008) as a combination of multiple – usually symmetric – copulas. The main thrust of the paper is to provide new theoretical properties including exact tail dependence expressions and stability properties. A subclass of Liebscher copulas obtained by combining comonotonic copulas is studied in more detail.We establish further dependence properties for copulas of this class and show that they are characterized by an arbitrary number of singular components. Furthermore, we introduce a novel iterative representation for general Liebscher copulas which de facto insures uniform margins, thus relaxing a constraint of Liebscher’s original construction. Besides, we show that this iterative construction proves useful for inference by developing an Approximate Bayesian computation sampling scheme. This inferential procedure is demonstrated on simulated data and is compared to a likelihood-based approach in a setting where the latter is available.
version--HAL.pdf (2.02 Mo) Télécharger le fichier
hal-01963975 , version 1 (21-12-2018)
hal-01963975 , version 2 (28-06-2019)
Julyan Arbel, Marta Crispino, Stéphane Girard. Dependence properties and Bayesian inference for asymmetric multivariate copulas. Journal of Multivariate Analysis, 2019, 174, pp.104530:1-20. ⟨10.1016/j.jmva.2019.06.008⟩. ⟨hal-01963975v2⟩
267 Consultations
155 Téléchargements
