Determination of all minimal cut-sets between a vertex pair in an undirected graph, IEEE Transactions on Reliability, vol.31, issue.2, pp.167-171, 1982. ,
Calculating bounds on reachability and connectedness in stochastic networks, Networks, vol.13, issue.2, pp.253-278, 1983. ,
An implicit enumeration scheme for proper cut generation, Technometrics, vol.12, issue.4, pp.775-788, 1970. ,
La theorie des graphes, 1958. ,
A better heuristic for orthogonal graph drawings, Comput. Geom, vol.9, issue.3, pp.159-180, 1998. ,
, , vol.5, pp.253-298, 1975.
Lower bounds on two-terminal network reliability, Discrete Applied Mathematics, vol.21, issue.3, pp.185-198, 1988. ,
On the number of minimum cuts in a graph, SIAM Journal on Discrete Mathematics, vol.18, issue.1, pp.177-194, 2004. ,
Computing an st-numbering, Theoretical Computer Science, vol.2, issue.3, pp.339-344, 1976. ,
Algorithm to aid in the design of large scale networks, LARGE SCALE SYST, vol.8, issue.2, pp.147-156, 1985. ,
, Efficient algorithms for listing combinatorial structures, 2009.
On finding the k best cuts in a network, Operations Research Letters, vol.2, issue.6, pp.303-305, 1984. ,
An exact lower bound on the number of cut-sets in multigraphs, Networks, vol.24, issue.8, pp.429-443, 1994. ,
The maximum connectivity of a graph, Proceedings of the National Academy of Sciences, vol.48, issue.7, pp.1142-1146, 1962. ,
A method for evaluating all the minimal cuts of a graph, IEEE transactions on reliability, vol.36, issue.5, pp.539-545, 1987. ,
A theorem for finite sets. Theory of Graphs, pp.187-207, 1968. ,
Generating cut conjunctions in graphs and related problems, Algorithmica, vol.51, issue.3, pp.239-263, 2008. ,
The number of simplices in a complex, Mathematical optimization techniques, vol.10, pp.251-278, 1963. ,
A gaussian elimination algorithm for the enumeration of cut sets in a graph, J. ACM, vol.23, issue.1, pp.58-73, 1976. ,
On the structure of all minimum cuts in a network and applications, Mathematical Programming, vol.22, pp.121-121, 1982. ,
, Microelectronics Reliability, vol.32, pp.1291-1310, 1992.
Computing network reliability in time polynomial in the number of cuts, Operations Research, vol.32, issue.3, pp.516-526, 1984. ,
A paradigm for listing (s, t)-cuts in graphs, Algorithmica, vol.15, issue.4, pp.351-372, 1996. ,
Rectilinear planar layouts and bipolar orientations of planar graphs, Discrete & Computational Geometry, vol.1, pp.343-353, 1986. ,
URL : https://hal.archives-ouvertes.fr/hal-00259777
Iterative algorithms for generating minimal cutsets in directed graphs, Networks, vol.16, issue.2, pp.133-147, 1986. ,
A unified approach a visibility representation of planar graphs, Discrete & Computational Geometry, vol.1, pp.321-341, 1986. ,
An algorithm to enumerate all cutsets of a graph in linear time per cutset, Journal of the ACM (JACM), vol.27, issue.4, pp.619-632, 1980. ,
A recursive approach for enumerating minimal cutsets in a network, IEEE transactions on reliability, vol.43, issue.3, pp.383-388, 1994. ,
Efficient algorithms for the problems of enumerating cuts by non-decreasing weights, Algorithmica, vol.56, issue.3, pp.297-312, 2010. ,
