Y. Afek and A. Bremler-barr, Self-stabilizing unidirectional network algorithms by power supply, Chicago J. Theor. Comput. Sci, 1998.
G. Antonoiu and P. Srimani, A self-stabilizing distributed algorithm to find the center of a tree graph, Parallel Algorithms and Applications, vol.10, issue.34, pp.237-248, 1997.
A. Arora, P. C. Attie, M. Evangelist, and M. G. Gouda, Convergence of iteration systems, Distributed Computing, vol.7, issue.1, pp.43-53, 1993.
J. Beauquier, M. Gradinariu, and C. Johnen, Cross-over composition-enforcement of fairness under unfair adversary, WSS'01, pp.19-34, 2001.
L. Blin, F. Boubekeur, and S. Dubois, A self-stabilizing memory efficient algorithm for the minimum diameter spanning tree under an omnipotent daemon, IPDPS'15, pp.1-10, 2015.
URL : https://hal.archives-ouvertes.fr/hal-01201859
L. Blin, S. Dolev, M. Potop-butucaru, and S. Rovedakis, Fast selfstabilizing minimum spanning tree construction, DISC'10, pp.480-494, 2010.
URL : https://hal.archives-ouvertes.fr/hal-00492398
L. Blin, P. Fraigniaud, and B. Patt-shamir, On proof-labeling schemes versus silent self-stabilizing algorithms, SSS'14, pp.18-32, 2014.
URL : https://hal.archives-ouvertes.fr/hal-01102123
L. Blin, M. Potop-butucaru, and S. Rovedakis, A superstabilizing log (n)-approximation algorithm for dynamic steiner trees, SSS'09, pp.133-148, 2009.
URL : https://hal.archives-ouvertes.fr/hal-00363003
L. Blin, M. Potop-butucaru, and S. Rovedakis, Self-stabilizing minimum degree spanning tree within one from the optimal degree, J. of Parallel and Distributed Computing, vol.71, issue.3, pp.438-449, 2011.
URL : https://hal.archives-ouvertes.fr/inria-00336713
L. Blin and S. Tixeuil, Compact deterministic self-stabilizing leader election-the exponential advantage of being talkative, DISC'13, pp.76-90, 2013.
URL : https://hal.archives-ouvertes.fr/hal-00930095
S. Bruell, S. Ghosh, M. Karaata, and S. Pemmaraju, Self-stabilizing algorithms for finding centers and medians of trees, SIAM Journal of Computing, vol.29, issue.2, pp.600-614, 1999.
J. Burman and S. Kutten, Time optimal asynchronous self-stabilizing spanning tree, DISC'07, pp.92-107, 2007.
F. Butelle, C. Lavault, and M. Bui, A uniform self-stabilizing minimum diameter tree algorithm (extended abstract), WDAG'95, pp.257-272, 1995.
Z. Collin and S. Dolev, Self-stabilizing depth-first search, Information Processing Letters, vol.49, issue.6, pp.297-301, 1994.
A. Cournier, A new polynomial silent stabilizing spanning-tree construction algorithm, SIROCCO'09, pp.141-153, 2009.
A. Cournier, S. Rovedakis, and V. Villain, The first fully polynomial stabilizing algorithm for BFS tree construction, OPODIS'11, pp.159-174, 2011.
URL : https://hal.archives-ouvertes.fr/hal-01009450
A. Datta and L. Larmore, Leader election and centers and medians in tree networks, SSS'13, pp.113-132, 2013.
A. Datta, L. Larmore, and P. Vemula, An o(n)-time self-stabilizing leader election algorithm, J. Parallel Distrib. Comput, vol.71, issue.11, pp.1532-1544, 2011.
E. Dijkstra, Self-stabilizing systems in spite of distributed control, Communication of the ACM, vol.17, issue.11, pp.643-644, 1974.
S. Dolev, Self-stabilization, 2000.
URL : https://hal.archives-ouvertes.fr/inria-00627780
S. Dolev, A. Israeli, and S. Moran, Self-stabilization of dynamic systems assuming only read/write atomicity, (PODC'90, pp.103-117, 1990.
S. Dolev, A. Israeli, and S. Moran, Self-stabilization of dynamic systems assuming only read/write atomicity, Distributed Computing, vol.7, issue.1, pp.3-16, 1993.
S. Dolev, A. Israeli, and S. Moran, Resource bounds for self-stabilizing message-driven protocols, SIAM J. Comput, vol.26, issue.1, pp.273-290, 1997.
S. Dolev, A. Israeli, and S. Moran, Uniform dynamic self-stabilizing leader election, IEEE Trans. Parallel Distrib. Syst, vol.8, issue.4, pp.424-440, 1997.
S. Dolev and T. Herman, Parallel composition of stabilizing algorithms, WSS'99, pp.25-32, 1999.
S. Dubois and S. Tixeuil, A taxonomy of daemons in self-stabilization, ArXiv eprint, 2011.
URL : https://hal.archives-ouvertes.fr/hal-00628390
F. Gärtner, A survey of self-stabilizing spanning-tree construction algorithms, 2003.
M. G. Gouda and T. Herman, Adaptive programming, IEEE Trans. Software Eng, vol.17, issue.9, pp.911-921, 1991.
M. G. Gouda and N. J. Multari, Stabilizing communication protocols, IEEE Trans. Computers, vol.40, issue.4, pp.448-458, 1991.
S. Gupta, A. Bouabdallah, and P. Srimani, Self-stabilizing protocol for shortest path tree for multi-cast routing in mobile networks
, Euro-Par'00, pp.600-604, 2000.
R. Hassin and A. Tamir, On the minimum diameter spanning tree problem, Information Processing Letters, vol.53, issue.2, pp.109-111, 1995.
J. Ho, D. Lee, C. Chang, and C. Wong, Minimum diameter spanning trees and related problems, SIAM Journal of Computing, vol.20, issue.5, pp.987-997, 1991.
S. Holzer and R. Wattenhofer, Optimal distributed all pairs shortest paths and applications, PODC'12, pp.355-364, 2012.
S. Huang and N. Chen, A self-stabilizing algorithm for constructing breadth-first trees, Information Processing Letters, vol.41, issue.2, pp.109-117, 1992.
S. Huang and N. Chen, Self-stabilizing depth-first token circulation on networks, Distributed Computing, vol.7, issue.1, pp.61-66, 1993.
T. Huang, A self-stabilizing algorithm for the shortest path problem assuming read/write atomicity, J. Comput. Syst. Sci, vol.71, issue.1, pp.70-85, 2005.
E. Korach, D. Rotem, and N. Santoro, Distributed algorithms for finding centers and medians in networks, ACM Transactions on Programming Languages and Systems, vol.6, issue.3, pp.380-401, 1984.
A. Korman, S. Kutten, and T. Masuzawa, Fast and compact self stabilizing verification, computation, and fault detection of an MST, PODC'11, pp.311-320, 2011.
URL : https://hal.archives-ouvertes.fr/hal-01240211
A. Kosowski and L. Kuszner, A self-stabilizing algorithm for finding a spanning tree in a polynomial number of moves, PPAM'05, pp.75-82, 2005.
D. Peleg, L. Roditty, and E. Tal, Distributed algorithms for network diameter and girth, ICALP'12, pp.660-672, 2012.
F. Petit and V. Villain, Time and space optimality of distributed depth-first token circulation algorithms, WDAS'99, pp.91-106, 1999.
L. Roditty and V. Williams, Fast approximation algorithms for the diameter and radius of sparse graphs, STOC'13, pp.515-524, 2013.
S. , Algorithms and Theory of Computation Handbook, chapter Selfstabilizing Algorithms, vol.45, pp.26-27, 2009.
G. Varghese, Compositional proofs of self-stabilizing protocols, WSS'97, pp.80-94, 1997.
