Subresultants of $(x-\alpha)^m$ and $(x-\beta)^n$, Jacobi polynomials and complexity - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Journal of Symbolic Computation Année : 2020
In an earlier article together with Carlos D'Andrea [BDKSV2017], we described explicit expressions for the coefficients of the order-$d$ polynomial subresultant of $(x-\alpha)^m$ and $(x-\beta)^n $ with respect to Bernstein's set of polynomials $\{(x-\alpha)^j(x-\beta)^{d-j}, \, 0\le j\le d\}$, for $0\le d<\min\{m, n\}$. The current paper further develops the study of these structured polynomials and shows that the coefficients of the subresultants of $(x-\alpha)^m$ and $(x-\beta)^n$ with respect to the monomial basis can be computed in linear arithmetic complexity, which is faster than for arbitrary polynomials. The result is obtained as a consequence of the amazing though seemingly unnoticed fact that these subresultants are scalar multiples of Jacobi polynomials up to an affine change of variables.
BKSV19-arxiv2.pdf (379.13 Ko) Télécharger le fichier
hal-01966640 , version 1 (29-12-2018)
hal-01966640 , version 2 (10-10-2019)
Domaine public
Alin Bostan, T Krick, A Szanto, M Valdettaro. Subresultants of $(x-\alpha)^m$ and $(x-\beta)^n$, Jacobi polynomials and complexity. Journal of Symbolic Computation, 2020, 101, pp.330-351. ⟨10.1016/j.jsc.2019.10.003⟩. ⟨hal-01966640v2⟩
51 Consultations
329 Téléchargements
