An almost global notion of input-to-state stability, IEEE Trans. Automatic Control, vol.49, pp.866-874, 2004. ,
On input-to-state stability with respect to decomposable invariant sets, Proc. 52nd IEEE Conference on Decision and Control, pp.5897-5902, 2013. ,
Characterizations of input-to-state stability for systems with multiple invariant sets, IEEE Trans. Automatic Control, vol.60, issue.12, pp.3242-3256, 2015. ,
URL : https://hal.archives-ouvertes.fr/hal-01136819
Detection of multistability, bifurcations and hysteresis in a large class of biological positivefeedback systems, Proc. Natl. Acad. Sci. USA, vol.101, pp.1822-1827, 2004. ,
Stability robustness in the presence of exponentially unstable isolated equilibria, IEEE Trans. Automatic Control, vol.56, pp.1582-1592, 2011. ,
URL : https://hal.archives-ouvertes.fr/hal-00554432
Multi-stability in monotone input/output systems, Systems&Control Lett, vol.51, pp.185-202, 2004. ,
Conditions for almost global attractivity of a synchronous generator connected to an infinite bus, IEEE Transactions on Automatic Control, vol.62, issue.10, pp.4905-4916, 2017. ,
URL : https://hal.archives-ouvertes.fr/hal-01461606
Stability Theory of Dynamical Systems, 1970. ,
Bistable biological systems: A characterization through local compact input-to-state stability, IEEE Trans. Automatic Control, vol.45, pp.87-100, 2008. ,
The Stability of Motion, 1961. ,
Bregman storage functions for microgrid control, IEEE Transactions on Automatic Control, vol.63, issue.1, pp.53-68, 2018. ,
Synchronization and transient stability in power networks and non-uniform Kuramoto oscillators, SIAM Journal on Control and Optimization, vol.50, issue.3, pp.1616-1642, 2012. ,
Synchronization in complex networks of phase oscillators: A survey, Automatica, vol.50, issue.6, pp.1539-1564, 2014. ,
Hidden attractors in dynamical systems, Physics Reports, vol.637, pp.1-50, 2016. ,
Global Lyapunov analysis of multi-stable nonlinear systems, SIAM Journal on Optimization and Control, vol.50, issue.5, pp.3132-3154, 2012. ,
URL : https://hal.archives-ouvertes.fr/hal-00745623
On necessary conditions of instability and design of destabilizing controls, Proc. 53rd IEEE Conference on Decision and Control, pp.3915-3917, 2014. ,
URL : https://hal.archives-ouvertes.fr/hal-01066282
A new criterion for boundedness of solutions for a class of periodic systems, Proc. 17th European Control Conference (ECC), 2018. ,
URL : https://hal.archives-ouvertes.fr/hal-01755084
A relaxed characterization of ISS for periodic systems with multiple invariant sets, European Journal of Control, vol.37, issue.9, pp.1-7, 2017. ,
URL : https://hal.archives-ouvertes.fr/hal-01351139
Robustness of delayed multistable systems with application to droop-controlled inverter-based microgrids, International Journal of Control, vol.89, issue.5, pp.909-918, 2016. ,
URL : https://hal.archives-ouvertes.fr/hal-01211454
Oscillatority of nonlinear systems with static feedback, SIAM Journal on Optimization and Control, vol.48, issue.2, pp.618-640, 2009. ,
Differential analysis of nonlinear systems: Revisiting the pendulum example, Proc. 53rd IEEE Conference on Decision and Control, pp.3848-3859, 2014. ,
A differential Lyapunov framework for contraction analysis, IEEE Transactions on Automatic Control, vol.59, issue.3, pp.614-628, 2014. ,
Differential positivity on compact sets, Decision and Control (CDC), 2015 IEEE 54th Annual Conference on, pp.6355-6360, 2015. ,
Stability of nonlinear systems with non unique equilibrium, 1978. ,
Nonlinear Oscillations, Dynamical Systems, and Bifurcations of Vector Fields, Applied Mathematical Sciences, vol.42, 1983. ,
Stability of Motion, 1967. ,
Nonlinear Systems, 1992. ,
Stability analysis in terms of two measures, 1993. ,
Analytical method for computation of phase-detector characteristic, IEEE Transactions on Circuits and Systems II: Express Briefs, vol.59, issue.10, pp.633-637, 2012. ,
Hold-in, pull-in, and lock-in ranges of pll circuits: Rigorous mathematical definitions and limitations of classical theory, IEEE Transactions on Circuits and Systems I: Regular Papers, vol.62, issue.10, pp.2454-2464, 2015. ,
On the boundedness of the trajectories of phase systems, Siberian Mathematical Journal, vol.15, issue.3, pp.491-495, 1974. ,
On contraction analysis of nonlinear systems, Automatica, vol.34, issue.6, pp.683-696, 1998. ,
The general problem of the stability of motion, 1992. ,
Filtrations, decompositions, and explosions, American Journal of Mathematics, vol.97, issue.4, pp.1029-1047, 1975. ,
New direct Lyapunov-type method for studying synchronization problems, Automatica, vol.13, pp.139-151, 1977. ,
Transient stabilization of multimachine power systems with nontrivial transfer conductances, IEEE Trans. Automatic Control, vol.50, issue.1, pp.60-75, 2005. ,
Convergent dynamics, a tribute to boris pavlovich demidovich, Systems & Control Letters, vol.52, issue.3-4, pp.257-261, 2004. ,
A dual to Lyapunov's stability theorem, Systems&Control Lett, vol.42, pp.161-168, 2001. ,
Stability and stabilization of motion with respect to part of variables, 1987. ,
On stability of a distributed averaging PI frequency and active power controlled differential-algebraic power system model, Proc. European Control Conference, pp.1487-1492, 2016. ,
Almost global synchronization in multi-machine power systems, Proc. 57th IEEE Conference on Decision and Control (CDC), 2018. ,
URL : https://hal.archives-ouvertes.fr/hal-01888553
Conditions for stability of droop-controlled inverter-based microgrids, Automatica, vol.50, issue.10, pp.2457-2469, 2015. ,
URL : https://hal.archives-ouvertes.fr/hal-01262877
An input-to-state stability approach to verify almost global stability of a synchronous-machine-infinite-bus system, Phil. Trans. R. Soc. A, vol.375, p.20160304, 2017. ,
URL : https://hal.archives-ouvertes.fr/hal-01483463
Analysis of interconnected oscillators by dissipativity theory, IEEE Trans. Automatic Control, vol.52, pp.256-270, 2007. ,
DOI : 10.1109/tac.2006.890471
URL : http://orbi.ulg.ac.be/bitstream/2268/33235/1/published.pdf
Synchronization in complex networks and its application-a survey of recent advances and challenges, Annual Reviews in Control, vol.38, issue.2, pp.184-198, 2014. ,
An internal model approach to (optimal) frequency regulation in power grids with time-varying voltages, Automatica, vol.64, pp.240-253, 2016. ,
DOI : 10.1016/j.automatica.2015.11.021
URL : http://arxiv.org/pdf/1403.7019
L2-Gain and Passivity Techniques in Nonlinear Control, 2000. ,
Stability of stationary sets in control systems with discontinuous nonlinearities, volume 14 of Series on stability, vibration, and control of systems, 2004. ,
