3D ConvNet improves macromolecule localization in 3D cellular cryo-electron tomograms - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2018
Cryo-electron tomography (cryo-ET) allows one to capture 3D images of cells in a close to native state, at sub-nanometer resolution. However, noise and artifact levels are such that heavy computational processing is needed to access the image content. In this paper, we propose a deep learning framework to accurately and jointly localize multiple types and states of macromolecules in cellular cryo-electron tomograms. We compare this framework to the commonly-used template matching method on both synthetic and experimental data. On synthetic image data, we show that our framework is very fast and produces superior detection results. On experimental data, the detection results obtained by our method correspond to an overlap rate of 86% with the expert annotations, and comparable resolution is achieved when applying subtomogram averaging. In addition, we show that our method can be combined to template matching procedures to reliably increase the number of expected detections. In our experiments, this strategy was able to find additional 20.5% membrane-bound ribosomes that were missed or discarded during manual annotation.
paper_dl.pdf (3.1 Mo) Télécharger le fichier
hal-01966819 , version 1 (29-12-2018)
  • HAL Id : hal-01966819 , version 1
Emmanuel Moebel, Antonio Martinez, Damien Larivière, Julio Ortiz, Wolfgang Baumeister, et al.. 3D ConvNet improves macromolecule localization in 3D cellular cryo-electron tomograms. 2018. ⟨hal-01966819⟩
359 Consultations
520 Téléchargements
