An overview of diffusion models for intracellular dynamics analysis - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2018
We present an overview of diffusion models commonly used for quantifying the dynamics of intracellular particles (e.g., biomolecules) inside living cells. It is established that inference on the modes of mobility of molecules is central in cell biology since it reflects interactions between structures and determines functions of biomolecules in the cell. In that context, Brownian motion is a key component in short distance transportation (e.g., connectivity for signal transduction). Another dynamical process that have been heavily studied in the past decade is the motor-mediated transport (e.g., dynein, kinesin, myosin) of molecules. Primarily supported by actin filament and microtubule network, it ensures spatial organization and temporal synchronization in the intracellular mechanisms and structures. Nevertheless, the complexity of internal structures and molecular processes in the living cell influence the molecular dynamics and prevent the systematic application of pure Brownian or directed motion modeling. On the one hand, cytoskeleton density will hinder the free displacement of the particle, a phenomenon called subdiffusion. On the other hand, the cytoskeleton elasticity combined with thermal bending can contribute a phenomenon called superdiffusion. This paper discusses the basics of diffusion modes observed in cells, by introducing the essential properties of these processes. Applications of diffusion models include protein trafficking and transport, and membrane diffusion.
OverviewDiffusion_PreprintHAL2018.pdf (956.79 Ko) Télécharger le fichier
hal-01966825 , version 1 (29-12-2018)
  • HAL Id : hal-01966825 , version 1
Vincent Briane, Myriam Vimond, Charles Kervrann. An overview of diffusion models for intracellular dynamics analysis. 2018. ⟨hal-01966825⟩
156 Consultations
700 Téléchargements
