An assistant for quantitatively analyzing multi-granularity parallel region, High Performance Computing and Communications & 2013 IEEE International Conference on Embedded and Ubiquitous Computing (HPCC_EUC), p.698707, 2013. ,
Generating loops for scanning polyhedra: Cloog users guide, Polyhedron, vol.2, p.10, 2004. ,
Qemu, a fast and portable dynamic translator, Proceedings of the Annual Conference on USENIX Annual Technical Conference, 2005. ,
Fast data-locality proling of native execution, ACM SIGMETRICS Performance Evaluation Review, vol.33, p.169180, 2005. ,
Discovery of locality-improving refactorings by reuse path analysis, p.220229, 2006. ,
A practical automatic polyhedral program optimization system, PLDI, 2008. ,
Loop parallelization algorithms: From parallelism extraction to code generation, Parallel Comput, vol.24, p.444, 1998. ,
URL : https://hal.archives-ouvertes.fr/inria-00565000
Runtime analysis of application binaries for function level parallelism potential using qemu, Open Source Systems and Technologies (ICOSST), 2012 International Conference on, p.3339, 2012. ,
Rodinia: A benchmark suite for heterogeneous computing, IEEE International Symposium on, 2009. ,
A characterization of the rodinia benchmark suite with comparison to contemporary cmp workloads, Proceedings of the IEEE International Symposium on Workload Characterization (IISWC'10, p.111, 2010. ,
Fuzzy array dataow analysis, Proceedings of the Fifth ACM SIGPLAN Symposium on Principles and Practice of Parallel Programming, p.92101, 1995. ,
Embla-data dependence proling for parallel programming, Proceedings of the 2008 International Conference on Complex, Intelligent and Software Intensive Systems, p.780785, 2008. ,
Parametric integer programming, RAIRO-Operations Research, vol.22, p.243268, 1988. ,
, Encyclopedia of Parallel Computing, p.15811592, 2011.
Polly-performing polyhedral pptimizations on a low-level intermediate representation, Parallel Processing Letters, vol.22, p.1250010, 2012. ,
Data-ow/dependence proling for structured transformations ,
, Submitted to the ACM SIGPLAN Symposium on Principles and Practice of Parallel Programming (PPoPP'19, 2019.
Program instrumentation with qemu, Proceedings of the International QEMU User's Forum, p.11, 2011. ,
Dynamic trace-based analysis of vectorization potential of applications, ACM SIGPLAN Notices, vol.47, p.371382, 2012. ,
Prediction and trace compression of data access addresses through nested loop recognition, Proceedings of the 6th Annual IEEE/ACM International Symposium on Code Generation and Optimization, p.94103, 2008. ,
URL : https://hal.archives-ouvertes.fr/inria-00504597
Proling data-dependence to assist parallelization: Framework, scope, and optimization, Proceedings of the 2012 45th Annual IEEE/ACM International Symposium on Microarchitecture, p.437448, 2012. ,
Prospector: A dynamic data-dependence proler to help parallel programming, HotPar'10: Proceedings of the USENIX workshop on Hot Topics in parallelism, 2010. ,
Discopop: A proling tool to identify parallelization opportunities, Tools for High Performance Computing, p.3754, 2014. ,
Pinpointing data locality problems using datacentric analysis, Code Generation and Optimization (CGO), 2011 9th Annual IEEE/ACM International Symposium on, p.171180, 2011. ,
A framework for application performance diagnosis, 2014 IEEE International Symposium on Performance Analysis of Systems and Software (ISPASS, 2014. ,
Full runtime polyhedral optimizing loop transformations with the generation, instantiation, and scheduling of code-bones, Concurrency and Computation: Practice and Experience, vol.29, 2017. ,
Redux: A dynamic dataow tracer. Electronic Notes in Theoretical Computer Science, vol.89, p.149170, 2003. ,
Induction variable analysis with delayed abstractions, Proceedings of the First International Conference on High Performance Embedded Architectures and Compilers, 2005. ,
URL : https://hal.archives-ouvertes.fr/hal-01257294
Trace-based ane reconstruction of codes, Proceedings of the 2016 International Symposium on Code Generation and Optimization, p.139149, 2016. ,
Polyjit: Polyhedral optimization just in time, International Journal of Parallel Programming, 2018. ,
The polyhedral model of nonlinear loops, ACM Trans. Archit. Code Optim, vol.12, p.27, 2015. ,
URL : https://hal.archives-ouvertes.fr/hal-01244464
Semi-automatic extraction and exploitation of hierarchical pipeline parallelism using proling information, Proceedings of the 19th International Conference on Parallel Architectures and Compilation Techniques, p.377388, 2010. ,
GRAPHITE Two Years After: First Lessons Learned From Real-World Polyhedral Compilation, GCC Research Opportunities Workshop (GROW'10, 2010. ,
URL : https://hal.archives-ouvertes.fr/inria-00551516
Ecient symbolic analysis for optimizing compilers, International Conference on Compiler Construction, 2001. ,
The paralax infrastructure: automatic parallelization with a helping hand, Parallel Architectures and Compilation Techniques (PACT), 2010 19th International Conference on, p.389399, 2010. ,
Integrating proledriven parallelism detection and machine-learning-based mapping, ACM Transactions on Architecture and Code Optimization (TACO), vol.11, 2014. ,
