Improving phenotypic measurements in high-content imaging screens, p.2017 ,
Combogan: Unrestrained scalability for image domain translation, 2017. ,
Testing that distributions are close, 41st Annual Symposium on Foundations of Computer Science, FOCS 2000, pp.259-269, 2000. ,
Domain adaptation for microscopy imaging, IEEE Trans Med Imaging, vol.34, issue.5, pp.1125-1139, 2015. ,
Analysis of representations for domain adaptation, Proceedings of the 19th International Conference on Neural Information Processing Systems, NIPS'06, pp.137-144, 2006. ,
A theory of learning from different domains, Machine Learning, vol.79, pp.151-175, 2010. ,
Scalable unsupervised domain adaptation for electron microscopy, Medical Image Computing and Computer-Assisted Intervention-MICCAI 2016, pp.326-334, 2016. ,
Discriminative learning for differing training and test distributions, Proceedings of the 24th International Conference on Machine Learning, ICML '07, pp.81-88, 2007. ,
Statistical methods for analysis of high-throughput RNA interference screens, Nat. Methods, vol.6, issue.8, pp.569-575, 2009. ,
Integrating structured biological data by Kernel Maximum Mean Discrepancy, Bioinformatics, vol.22, issue.14, pp.49-57, 2006. ,
Domain separation networks. CoRR, 2016. ,
Stability and generalization, Journal of Machine Learning Research, vol.2, pp.499-526, 2002. ,
High-content phenotypic profiling of drug response signatures across distinct cancer cells, Mol. Cancer Ther, vol.9, issue.6, pp.1913-1926, 2010. ,
Partial transfer learning with selective adversarial networks, The IEEE Conference on Computer Vision and Pattern Recognition (CVPR), 2018. ,
A method for traffic sign detection in an image with learning from synthetic data, 14th International Conference Digital Signal Processing and its Applications, vol.2, pp.316-319, 2012. ,
Stargan: Unified generative adversarial networks for multi-domain image-to-image translation, The IEEE Conference on Computer Vision and Pattern Recognition (CVPR), 2018. ,
Torch7: A matlab-like environment for machine learning, BigLearn, NIPS Workshop, 2011. ,
Optimal transport for domain adaptation, IEEE Transactions on Pattern Analysis and Machine Intelligence, vol.39, issue.9, pp.1853-1865, 2017. ,
URL : https://hal.archives-ouvertes.fr/hal-01170705
Deepjdot: Deep joint distribution optimal transport for unsupervised domain adaptation, Devis Tuia, and Nicolas Courty, 2018. ,
Domain adaptation for statistical classifiers, J. Artif. Intell. Res, vol.26, pp.101-126, 2006. ,
Multi-domain learning by confidence-weighted parameter combination, Machine Learning, vol.79, pp.123-149, 2010. ,
Joint cross-domain classification and subspace learning for unsupervised adaptation, Pattern Recognition Letters, vol.65, pp.60-66, 2015. ,
Domain-adversarial training of neural networks, Journal of Machine Learning Research, vol.17, issue.59, pp.1-35, 2016. ,
URL : https://hal.archives-ouvertes.fr/hal-01624607
Deep reconstructionclassification networks for unsupervised domain adaptation, Computer Vision-ECCV, pp.597-613, 2016. ,
Connecting the dots with landmarks: Discriminatively learning domain-invariant features for unsupervised domain adaptation, Proceedings of the 30th International Conference on International Conference on Machine Learning, vol.28, 2013. ,
A kernel method for the two-sample-problem, NIPS, pp.513-520, 2007. ,
Correcting sample selection bias by unlabeled data, Proceedings of the 19th International Conference on Neural Information Processing Systems, NIPS'06, pp.601-608, 2006. ,
Image-to-image translation with conditional adversarial networks, CVPR, pp.5967-5976, 2017. ,
, Convolutional architecture for fast feature embedding, 2014.
SciPy: Open source scientific tools for Python, 2001. ,
Unsupervised domain adaptation in brain lesion segmentation with adversarial networks, Information Processing in Medical Imaging, pp.597-609, 2017. ,
Improving drug discovery with high-content phenotypic screens by systematic selection of reporter cell lines, Nat. Biotechnol, vol.34, issue.1, pp.70-77, 2016. ,
Detecting change in data streams, Proceedings of the Thirtieth International Conference on Very Large Data Bases, vol.30, pp.180-191, 2004. ,
Domain adaptation by mixture of alignments of second-or higherorder scatter tensors, 2016. ,
Imagenet classification with deep convolutional neural networks, Advances in Neural Information Processing Systems, vol.25, pp.1097-1105, 2012. ,
Gradient-based learning applied to document recognition, Proceedings of the IEEE, vol.86, pp.2278-2324, 1998. ,
Unsupervised image-to-image translation networks, Advances in Neural Information Processing Systems, vol.30, pp.700-708, 2017. ,
Annotated high-throughput microscopy image sets for validation, Nat. Methods, vol.9, issue.7, p.637, 2012. ,
Learning transferable features with deep adaptation networks, Proceedings of the 32Nd International Conference on International Conference on Machine Learning, vol.37, pp.97-105, 2015. ,
Deep transfer learning with joint adaptation networks. CoRR, abs/1605.06636, 2016. ,
Domain adaptation with randomized multilinear adversarial networks. CoRR, abs/1705.10667, 2017. ,
Learning and domain adaptation, Algorithmic Learning Theory, 20th International Conference, ALT, pp.4-6, 2009. ,
Domain adaptation with multiple sources, Proceedings of the 21st International Conference on Neural Information Processing Systems, NIPS'08, pp.1041-1048, 2008. ,
Unified deep supervised domain adaptation and generalization, The IEEE International Conference on Computer Vision (ICCV), 2017. ,
Domain generalization via invariant feature representation, Proceedings of the 30th International Conference on International Conference on Machine Learning, vol.28, 2013. ,
A Threshold Selection Method from Gray-level Histograms, IEEE Transactions on Systems, Man and Cybernetics, vol.9, issue.1, pp.62-66, 1979. ,
A survey on transfer learning, IEEE Transactions on Knowledge and Data Engineering, vol.22, issue.10, pp.1345-1359, 2010. ,
Multi-adversarial domain adaptation, Proceedings of the 32nd AAAI Conference on Artificial Intelligence, 2018. ,
Direct transfer of learned information among neural networks, Proceedings of the Ninth National Conference on Artificial Intelligence (AAAI-91), AAAI'91, pp.584-589, 1991. ,
Globally optimal stitching of tiled 3D microscopic image acquisitions, Bioinformatics, vol.25, issue.11, pp.1463-1465, 2009. ,
ImageNet Large Scale Visual Recognition Challenge, International Journal of Computer Vision (IJCV), vol.115, issue.3, pp.211-252, 2015. ,
Adapting visual category models to new domains, Computer Vision-ECCV 2010, pp.213-226, 2010. ,
Generate to adapt: Aligning domains using generative adversarial networks, 2017. ,
NIH Image to ImageJ: 25 years of image analysis, Nat. Methods, vol.9, issue.7, pp.671-675, 2012. ,
An empirical analysis of domain adaptation algorithms for genomic sequence analysis, Proceedings of the 21st International Conference on Neural Information Processing Systems, NIPS'08, pp.1433-1440, 2008. ,
Improving predictive inference under covariate shift by weighting the log-likelihood function, Journal of Statistical Planning and Inference, vol.90, issue.2, pp.227-244, 2000. ,
A DIRT-T approach to unsupervised domain adaptation, Proceedings of the 6th International Conference on Learning Representations (ICLR), 2018. ,
Dynamic proteomics in individual human cells uncovers widespread cell-cycle dependence of nuclear proteins, Nat. Methods, vol.3, issue.7, pp.525-531, 2006. ,
Very deep convolutional networks for large-scale image recognition. CoRR, abs/1409.1556, 2014. ,
Man vs. computer: Benchmarking machine learning algorithms for traffic sign recognition, Neural Networks, 2012. ,
Computer vision for image-based transcriptomics, Methods, vol.85, pp.44-53, 2015. ,
Deep coral: Correlation alignment for deep domain adaptation, Computer Vision-ECCV 2016 Workshops, pp.443-450, 2016. ,
Return of frustratingly easy domain adaptation, Proceedings of the 29th AAAI Conference on Artificial Intelligence, AAAI, 2016. ,
Unsupervised cross-domain image generation, 2016. ,
Simultaneous deep transfer across domains and tasks, 2015 IEEE International Conference on Computer Vision (ICCV), pp.4068-4076, 2015. ,
Deep domain confusion: Maximizing for domain invariance. CoRR, abs/1412, vol.3474, 2014. ,
Adversarial discriminative domain adaptation. CoRR, abs/1702.05464, 2017. ,
Leveraging heterogeneity across multiple data sets increases accuracy of cell-mixture deconvolution and reduces biological and technical biases. bioRxiv, 2017. ,
Visualizing data using t-SNE, Journal of Machine Learning Research, vol.9, pp.2579-2605, 2008. ,
Transfer learning improves supervised image segmentation across imaging protocols, I E E E Transactions on Medical Imaging, vol.34, issue.5, pp.1018-1030, 2015. ,
, Statistical Learning Theory, 1998.
Learning deep feature representations with domain guided dropout for person re-identification, Proceedings of the **th Conference on Computer Vision and Pattern Recognition, CVPR'16, 2016. ,
A Survey of Transfer and Multitask Learning in Bioinformatics, Journal of Computing Science and Engineering, 2011. ,
A unified perspective on multi-domain and multi-task learning, Proceedings of the 3d International Conference on Representation Learning, ICLR'15, 2015. ,
Dualgan: Unsupervised dual learning for image-toimage translation, ICCV, pp.2868-2876, 2017. ,
Generalization bounds for domain adaptation, Advances in Neural Information Processing Systems, vol.25, pp.3320-3328, 2012. ,
Importance weighted adversarial nets for partial domain adaptation, 2018. ,
Unpaired image-to-image translation using cycle-consistent adversarial networks, ICCV, pp.2242-2251, 2017. ,
