Co-scheduling Amdahl applications on cache-partitioned systems - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue International Journal of High Performance Computing Applications Année : 2018
Cache-partitioned architectures allow subsections of the shared last-level cache (LLC) to be exclusively reserved for some applications. This technique dramatically limits interactions between applications that are concurrently executing on a multi-core machine. Consider n applications that execute concurrently, with the objective to minimize the makespan, defined as the maximum completion time of the n applications. Key scheduling questions are: (i) which proportion of cache and (ii) how many processors should be given to each application? In this paper, we provide answers to (i) and (ii) for Amdahl applications. Even though the problem is shown to be NP-complete, we give key elements to determine the subset of applications that should share the LLC (while remaining ones only use their smaller private cache). Building upon these results, we design efficient heuristics for Amdahl applications. Extensive simulations demonstrate the usefulness of co-scheduling when our efficient cache partitioning strategies are deployed.
ijhpca-revised.pdf (677.66 Ko) Télécharger le fichier
hal-01670137 , version 1 (21-12-2017)
Guillaume Aupy, Anne Benoit, Sicheng Dai, Loïc Pottier, Padma Raghavan, et al.. Co-scheduling Amdahl applications on cache-partitioned systems. International Journal of High Performance Computing Applications, 2018, 32 (1), pp.123-138. ⟨10.1177/1094342017710806⟩. ⟨hal-01670137⟩
544 Consultations
189 Téléchargements
