Conference papers
Do Moldable Applications Perform Better on Failure-Prone HPC Platforms?
Abstract : This paper compares the performance of different approaches to tolerate failures using checkpoint/restart when executed on large-scale failure-prone platforms. We study (i) RIGID applications, which use a constant number of processors throughout execution; (ii) MOLDABLE applications, which can use a different number of processors after each restart following a fail-stop error; and (iii) GRIDSHAPED applications, which are moldable applications restricted to use rectangular processor grids (such as many dense linear algebra kernels). For each application type, we compute the optimal number of failures to tolerate before relinquishing the current allocation and waiting until a new resource can be allocated, and we determine the optimal yield that can be achieved. We instantiate our performance model with a realistic applicative scenario and make it publicly available for further usage.
Document type :
Conference papers
Complete list of metadata
https://hal.inria.fr/hal-01968448
Contributor : Equipe Roma Connect in order to contact the contributor
Submitted on : Wednesday, January 2, 2019 - 5:54:54 PM
Last modification on : Thursday, September 29, 2022 - 2:58:07 PM
Links full text
Identifiers
Collections
Citation
Valentin Le Fèvre, George Bosilca, Aurelien Bouteiller, Thomas Herault, Atsushi Hori, et al.. Do Moldable Applications Perform Better on Failure-Prone HPC Platforms?. Euro-Par 2018 - European Conference on Parallel Processing Worksops, Aug 2018, Torino, Italy. pp.787-799, ⟨10.1007/978-3-030-10549-5_61⟩. ⟨hal-01968448⟩
Share
Metrics
Record views
33
