New interface
Journal articles
LLN Minimal Fragment Forwarding - draft-ietf-6lo-minimal-fragment-00
Abstract : This document gives an overview of LLN Minimal Fragment Forwarding. When employing adaptation layer fragmentation in 6LoWPAN, it may be beneficial for a forwarder not to have to reassemble each packet in its entirety before forwarding it. This has been always possible with the original fragmentation design of RFC4944. This document is a companion document to [I-D.ietf-lwig-6lowpan-virtual-reassembly], which details the virtual Reassembly Buffer (VRB) implementation technique which reduces the latency and increases end-to-end reliability in route-over forwarding.
Complete list of metadata
Cited literature [8 references]  Display  Hide  Download
https://hal.inria.fr/hal-01968653
Contributor : Thomas Watteyne Connect in order to contact the contributor
Submitted on : Thursday, January 3, 2019 - 12:06:53 AM
Last modification on : Tuesday, October 25, 2022 - 4:17:49 PM
Long-term archiving on: : Thursday, April 4, 2019 - 1:42:00 PM
File
18_draft-ietf-6lo-minimal-frag...
Identifiers
  • HAL Id : hal-01968653, version 1
Collections
Citation
Thomas Watteyne, Carsten Bormann, Pascal Thubert. LLN Minimal Fragment Forwarding - draft-ietf-6lo-minimal-fragment-00. Internet Engineering Task Force, 2018. ⟨hal-01968653⟩
Share
Metrics
Record views
45
Files downloads
46
