Spectral Properties of Radial Kernels and Clustering in High Dimensions - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2020
In this paper, we study the spectrum and the eigenvectors of radial kernels for mixtures of distributions in R n. Our approach focuses on high dimensions and relies solely on the concentration properties of the components in the mixture. We give several results describing of the structure of kernel matrices for a sample drawn from such a mixture. Based on these results, we analyze the ability of kernel PCA to cluster high dimensional mixtures. In particular, we exhibit a specific kernel leading to a simple spectral algorithm for clustering mixtures with possibly common means but different covariance matrices. We show that the minimum angular separation between the covariance matrices that is required for the algorithm to succeed tends to 0 as n goes to infinity.
hdkernel.pdf (395.93 Ko) Télécharger le fichier
hal-01969956 , version 1 (04-01-2019)
hal-01969956 , version 2 (23-01-2019)
hal-01969956 , version 3 (15-03-2019)
hal-01969956 , version 4 (25-06-2019)
hal-01969956 , version 5 (27-06-2019)
hal-01969956 , version 6 (28-06-2019)
hal-01969956 , version 7 (06-01-2020)
  • HAL Id : hal-01969956 , version 7
David Cohen-Steiner, Alba Chiara de Vitis. Spectral Properties of Radial Kernels and Clustering in High Dimensions. 2020. ⟨hal-01969956v7⟩
356 Consultations
372 Téléchargements
