Towards Combining Model Checking and Proof Checking - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue The Computer Journal Année : 2019
Model checking and automated theorem proving are two pillars of formal verification methods. This paper investigates model checking from an automated theorem proving perspective, aiming at combining the expressiveness of automated theorem proving and the complete automaticity of model checking. It places the focus on the verification of temporal logic properties of Kripke models. The main contributions are: (1) introducing an extended computation tree logic that allows polyadic predicate symbols; (2) designing a proof system for this logic, taking Kripke models as parameters; (3) developing a proof search algorithm for this system and a new automated theorem prover to implement it. The verification process of the new prover is completely automatic, and produces either a counterexample when the property does not hold, or a certificate when it does. The experimental results compare well to existing state-of-the-art tools on some benchmarks, and the efficiency is illustrated by application to an air traffic control problem.
sctl_paper.pdf (698.63 Ko) Télécharger le fichier
illustrative_example-eps-converted-to.pdf (36.1 Ko) Télécharger le fichier
sca-eps-converted-to.pdf (37.17 Ko) Télécharger le fichier
sctl_paper.synctex.gz (703.29 Ko) Télécharger le fichier
uv-eps-converted-to.pdf (152.56 Ko) Télécharger le fichier
hal-01970274 , version 1 (04-01-2019)
Ying Jiang, Jian Liu, Gilles Dowek, Kailiang Ji. Towards Combining Model Checking and Proof Checking. The Computer Journal, In press, ⟨10.1093/comjnl/bxy112⟩. ⟨hal-01970274⟩
155 Consultations
281 Téléchargements
