An experimental comparison of min-cut/max-flow algorithms for energy minimization in vision, IEEE Transactions on Pattern Analysis and Machine Intelligence, vol.26, issue.9, pp.1124-1137, 2004. ,
An approach to achieving optimized complex sheet inflation under constraints, Computers & Graphics, vol.59, pp.39-56, 2016. ,
Texture tiling on 3d models using automatic polycube-maps and wang tiles, Journal of Information Science and Engineering, vol.26, issue.1, pp.291-305, 2010. ,
Polycube Simplification for Coarse Layouts of Surfaces and Volumes, Computer Graphics Forum, vol.35, pp.11-20, 2016. ,
Efficient Volumetric PolyCubeMap Construction, Computer Graphics Forum, vol.35, pp.97-106, 2016. ,
Mesh morphing using polycube-based cross-parameterization, Computer Animation and Virtual Worlds, vol.16, pp.499-508, 2005. ,
All-hex meshing using closed-form induced polycube, ACM Trans. Graph, vol.35, issue.9, p.11, 2016. ,
Hexahedral Mesh Reparameterization from Aligned Base-complex, ACM Trans. Graph, vol.34, issue.4, pp.1-142, 2015. ,
Gurobi Optimizer Reference Manual, 2016. ,
All-Hex Mesh Generation via Volumetric PolyCube Deformation, Computer Graphics Forum, vol.30, p.7, 2011. ,
URL : https://hal.archives-ouvertes.fr/hal-00766792
1-Based Construction of Polycube Maps from Complex Shapes, ACM Trans. Graph, vol.33, issue.3, 2014. ,
A divide-and-conquer approach for automatic polycube map construction, Computers and Graphics, vol.33, pp.369-380, 2009. ,
Hexahedral shell mesh construction via volumetric polycube map, Proceedings of the 14th ACM symposium on solid and physical modeling, pp.127-136, 2010. ,
cinolib: a generic programming header only C++ library for processing polygonal and polyhedral meshes ,
Automatic PolyCubeMaps, Advances in Geometric Modeling and Processing, pp.3-16, 2008. ,
Quality guaranteed allhex mesh generation by a constrained volume iterative fitting algorithm, Computer-Aided Design, vol.67, pp.107-117, 2015. ,
Skeletondriven Adaptive Hexahedral Meshing of Tubular Shapes, Computer Graphics Forum, vol.35, pp.237-246, 2016. ,
Practical Hex-mesh Optimization via Edge-cone Rectification, ACM Trans. Graph, vol.34, issue.4, p.10, 2015. ,
PolyCut: Monotone Graph-cuts for PolyCube Base-complex Construction, ACM Trans. Graph, vol.32, p.7, 2013. ,
Pillowing doublets: refining a mesh to ensure that faces share at most one edge, 4th International Meshing Roundtable, pp.231-240, 1995. ,
A template-based approach for parallel hexahedral two-refinement, 24th International Meshing Roundtable Special Issue: Advances in Mesh Generation, vol.85, pp.34-52, 2017. ,
Adaptive mesh coarsening for quadrilateral and hexahedral meshes, Finite Elements in Analysis and Design, vol.46, pp.17-32, 2010. ,
The Verdict library reference manual, Sandia National Laboratories Technical Report, vol.9, issue.6, 2007. ,
Topologic and geometric constraint-based hexahedral mesh generation, vol.68, 2007. ,
Hexahedral mesh generation constraints, Engineering with Computers, vol.24, pp.195-213, 2008. ,
The whisker weaving algorithm: A connectivity-based method for constructing allhexahedral finite element meshes, International Journal for Numerical Methods in Engineering, vol.39, issue.2, pp.3327-3349, 1996. ,
PolyCube-Maps, ACM Trans. Graph, vol.23, issue.2, pp.853-860, 2004. ,
Hex mesh topological improvement based on frame field and sheet adjustment, 25th International Meshing Roundtable Special Issue: Advances in Mesh Generation, vol.103, p.11, 2018. ,
, Proceedings of the 2007 ACM Symposium on Solid and Physical Modeling, pp.241-251, 2007.
Sheet operation based block decomposition of solid models for hex meshing, 24th International Meshing Roundtable Special Issue: Advances in Mesh Generation, vol.85, pp.123-137, 2017. ,
Optimizing polycube domain construction for hexahedral remeshing, SIAM Conference on Geometric and Physical Modeling, vol.46, pp.58-68, 2013. ,
Direct Editing on Hexahedral Mesh through Dual Operations, 23rd International Meshing Roundtable (IMR23), vol.82, pp.149-161, 2014. ,
