Determining optical flow, Artificial Intelligence, vol.17, issue.1-3, pp.185-203, 1981. ,
Dense estimation and object-based segmentation of the optical flow with robust techniques, IEEE Transactions on Image Processing, vol.7, issue.5, pp.703-719, 1998. ,
Lucas/Kanade meets Horn/Schunck: Combining local and global optic flow methods, International Journal of Computer Vision, vol.61, issue.3, pp.211-231, 2005. ,
A quantitative analysis of current practices in optical flow estimation and the principles behind them, International Journal of Computer Vision, vol.106, issue.2, pp.115-137, 2014. ,
Dense estimation of fluid flows, IEEE Transactions on Pattern Analysis and Machine Intelligence, vol.24, issue.3, pp.365-380, 2002. ,
URL : https://hal.archives-ouvertes.fr/hal-00329724
Variational fluid flow measurements from image sequences: synopsis and perspectives, Experiments in Fluids, vol.48, issue.3, pp.369-393, 2010. ,
URL : https://hal.archives-ouvertes.fr/hal-00456162
Bayesian selection of scaling laws for motion modeling in images, Proceedings of the IEEE 12th International Conference on Computer Vision, pp.971-978, 2009. ,
Optical flow for incompressible turbulence motion estimation, Experiments in Fluids, vol.56, issue.1, pp.1-14, 2015. ,
URL : https://hal.archives-ouvertes.fr/hal-01102944
Optimal control formulation for determining optical flow, SIAM Journal on Scientific Computing, vol.24, issue.3, pp.818-847, 2003. ,
Variational assimilation of fluid motion from image sequence, SIAM Journal on Imaging Sciences, vol.1, issue.4, pp.343-363, 2008. ,
URL : https://hal.archives-ouvertes.fr/hal-00596149
An optimal control approach to the optical flow problem, Systems & Control Letters, vol.87, pp.1-9, 2016. ,
A stochastic filtering technique for fluid flow velocity fields tracking, IEEE Transactions on Pattern Analysis and Machine Intelligence, vol.31, issue.7, pp.1278-1293, 2009. ,
Variational algorithms for analysis and assimilation of meteorological observations: theoretical aspects, Tellus A: Dynamic Meteorology and Oceanography, vol.38, pp.97-110, 1986. ,
An ensemble-based four-dimensional variational data assimilation scheme. Part I: Technical formulation and preliminary test, Monthly Weather Review, vol.136, issue.9, pp.3363-3373, 2008. ,
Enhanced ensemble-based 4DVar scheme for data assimilation, Computers & Fluids, vol.115, pp.201-210, 2015. ,
URL : https://hal.archives-ouvertes.fr/hal-01144923
Surface quasi-geostrophic dynamics, Journal of Fluid Mechanics, vol.282, pp.1-20, 1995. ,
Dynamics of the upper oceanic layers in terms of surface quasigeostrophy theory, Journal of Physical Oceanography, vol.36, issue.2, pp.165-176, 2006. ,
URL : https://hal.archives-ouvertes.fr/hal-00270025
Analysis scheme in the ensemble Kalman filter, Monthly weather review, vol.126, issue.6, pp.1719-1724, 1998. ,
Geophysical flows under location uncertainty, Part II: Quasigeostrophic models and efficient ensemble spreading, Geophysical & Astrophysical Fluid Dynamics, 2017. ,
