Provably and Practically Efficient Granularity Control, ???v1 Long version, 2019. ,
The Data Locality of Work Stealing. Theory of Computing Systems, vol.35, pp.321-347, 2002. ,
Heartbeat Scheduling: Provable Efficiency for Nested Parallelism, Proceedings of the 39th ACM SIGPLAN Conference on Programming Language Design and Implementation, pp.769-782, 2018. ,
Scheduling Parallel Programs by Work Stealing with Private Deques, Proceedings of the 19th ACM SIGPLAN Symposium on Principles and Practice of Parallel Programming (PPoPP '13), 2013. ,
A work-efficient algorithm for parallel unordered depth-first search, Proceedings of the International Conference for High Performance Computing, Networking, Storage and Analysis, vol.67, p.12, 2015. ,
Oracle-guided scheduling for controlling granularity in implicitly parallel languages, Journal of Functional Programming, vol.26, p.23, 2016. ,
The Id Report: An Asychronous Language and Computing Machine, 1978. ,
, Lazy Tree Splitting. J. Funct. Program, vol.22, pp.382-438, 2012.
Internally deterministic parallel algorithms can be fast, PPoPP '12, pp.181-192, 2012. ,
A provable time and space efficient implementation of NESL, Proceedings of the 1st ACM SIGPLAN International Conference on Functional Programming, pp.213-225, 1996. ,
Implementation of a Portable Nested DataParallel Language, J. Parallel Distrib. Comput, vol.21, pp.4-14, 1994. ,
Scheduling multithreaded computations by work stealing, J. ACM, vol.46, pp.720-748, 1999. ,
Data parallel Haskell: a status report, Proceedings of the POPL 2007 Workshop on Declarative Aspects of Multicore Programming, pp.10-18, 2007. ,
X10: an object-oriented approach to non-uniform cluster computing, Proceedings of the 20th annual ACM SIGPLAN conference on Object-oriented programming, systems, languages, and applications (OOPSLA '05), pp.519-538, 2005. ,
An adaptive cut-off for task parallelism, 2008 SC-International Conference for High Performance Computing, Networking, Storage and Analysis, pp.1-11, 2008. ,
A Message Passing Implementation of Lazy Task Creation, Parallel Symbolic Computing, pp.94-107, 1992. ,
An efficient and general implementation of futures on large scale shared-memory multiprocessors, pp.93-22348, 1993. ,
Polling efficiently on stock hardware, Proceedings of the conference on Functional programming languages and computer architecture (FPCA '93, pp.179-187, 1993. ,
Implicitly threaded parallelism in Manticore, Journal of Functional Programming, vol.20, pp.1-40, 2011. ,
The Implementation of the Cilk-5 Multithreaded Language, PLDI, pp.212-223, 1998. ,
Hierarchical Memory Management for Mutable State, ACM SIGPLAN Symposium on Principles and Practice of Parallel Programming (PPOPP), 2018. ,
MULTILISP: a language for concurrent symbolic computation, ACM Transactions on Programming Languages and Systems, vol.7, pp.501-538, 1985. ,
Implementation of Multilisp: Lisp on a Multiprocessor, Proceedings of the 1984 ACM Symposium on LISP and functional Provably and Practically Efficient Granularity Control PPoPP '19, pp.9-17, 1984. ,
Backtracking-based load balancing, PPoPP '09. ACM, pp.55-64, 2009. ,
Using the run-time sizes of data structures to guide parallel-thread creation, Proceedings of the 1994 ACM conference on LISP and functional programming (LFP '94, pp.79-90, 1994. ,
Habanero-Java library: a Java 8 framework for multicore programming, 2014 International Conference on Principles and Practices of Programming on the Java Platform Virtual Machines, Languages and Tools, PPPJ '14, pp.75-86, 2014. ,
Intel Threading Building Blocks, 2011. ,
A static cut-off for task parallel programs, Proceedings of the 2016 International Conference on Parallel Architectures and Compilation, pp.139-150, 2016. ,
The Design Rationale for Multi-MLton, ML '10: Proceedings of the ACM SIGPLAN Workshop on ML, 2010. ,
Regular, shape-polymorphic, parallel arrays in Haskell, Proceedings of the 15th ACM SIGPLAN international conference on Functional programming (ICFP '10, pp.261-272, 2010. ,
A Java fork/join framework, Proceedings of the ACM 2000 conference on Java Grande (JAVA '00, pp.36-43, 2000. ,
The design of a task parallel library, Proceedings of the 24th ACM SIGPLAN conference on Object Oriented Programming Systems Languages and Applications (OOPSLA '09, pp.227-242, 2009. ,
A methodology for granularity-based control of parallelism in logic programs, Journal of Symbolic Computation, vol.21, pp.715-734, 1996. ,
Lazy task creation: a technique for increasing the granularity of parallel programs, IEEE Transactions on Parallel and Distributed Systems, vol.2, pp.264-280, 1991. ,
Lazy task creation: a technique for increasing the granularity of parallel programs, Conference record of the 1990 ACM Conference on Lisp and Functional Programming, pp.185-197, 1990. ,
, OpenMP Application Program Interface, 2008.
Low-cost process creation and dynamic partitioning in Qlisp, Parallel Lisp: Languages and Systems, vol.441, pp.182-199, 1990. ,
Hierarchical Memory Management for Parallel Programs, Proceedings of the 21st ACM SIGPLAN International Conference on Functional Programming, pp.392-406, 2016. ,
URL : https://hal.archives-ouvertes.fr/hal-01416237
Effective Scheduling Techniques for High-Level Parallel Programming Languages, 2010. ,
Flexible architectural support for fine-grain scheduling, Proceedings of the fifteenth edition of ASPLOS on Architectural support for programming languages and operating systems (ASPLOS '10), pp.311-322, 2010. ,
Lazy Scheduling: A Runtime Adaptive Scheduler for Declarative Parallelism, TOPLAS, vol.36, issue.10, 2014. ,
Parallel Execution of Lisp Programs. Ph.D. Dissertation, 1989. ,
Overview, Models of Computation, Brentâ??s Theorem, 2017. ,
