New interface
Journal articles
Explainable cardiac pathology classification on cine MRI with motion characterization by semi-supervised learning of apparent flow
Abstract : We propose a method to classify cardiac pathology based on a novel approach to extract image derived features to characterize the shape and motion of the heart. An original semi-supervised learning procedure, which makes efficient use of a large amount of non-segmented images and a small amount of images segmented manually by experts , is developed to generate pixel-wise apparent flow between two time points of a 2D+t cine MRI image sequence. Combining the apparent flow maps and cardiac seg-mentation masks, we obtain a local apparent flow corresponding to the 2D motion of myocardium and ventricular cavities. This leads to the generation of time series of the radius and thickness of myocardial segments to represent cardiac motion. These time series of motion features are reliable and explainable characteristics of pathological cardiac motion. Furthermore, they are combined with shape-related features to classify cardiac pathologies. Using only nine feature values as input, we propose an explain-able, simple and flexible model for pathology classification. On ACDC training set and testing set, the model achieves 95% and 94% respectively as classification accuracy. Its performance is hence comparable to that of the state-of-the-art. Comparison with various other models is performed to outline some advantages of our model.
Complete list of metadata
Cited literature [45 references]  Display  Hide  Download
https://hal.inria.fr/hal-01975880
Contributor : Qiao Zheng Connect in order to contact the contributor
Submitted on : Friday, March 29, 2019 - 1:46:15 AM
Last modification on : Friday, July 8, 2022 - 10:07:12 AM
File
1811.03433.pdf
Identifiers
Collections
Citation
Qiao Zheng, Hervé Delingette, Nicholas Ayache. Explainable cardiac pathology classification on cine MRI with motion characterization by semi-supervised learning of apparent flow. Medical Image Analysis, In press, 56, pp.80-95. ⟨10.1016/j.media.2019.06.001⟩. ⟨hal-01975880v2⟩
Share
Metrics
Record views
218
Files downloads
343
