Verifiable certificates for predicate subtyping - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2019
Adding predicate subtyping to higher-order logic yields a very expressive language in which type-checking is undecidable, making the definition of a system of verifiable certificates challenging. This work presents a solution to this issue with a minimal formalization of predicate subtyping, named PVS-Core, together with a system of verifiable certificates for PVS-Core, named PVS-Cert. PVS-Cert is based on the introduction of proof terms and explicit coercions. Its design is similar to that of PTSs with dependent pairs, at the exception of the definition of conversion, which is based on a specific notion of reduction → β * , corresponding to β-reduction combined with the erasure of coercions. The use of this reduction instead of the more standard reduction → βσ allows to establish a simple correspondence between PVS-Core and PVS-Cert. On the other hand, a type-checking algorithm is designed for PVS-Cert, built on proofs of type preservation of → βσ and strong normalization of both → βσ and → β *. Using these results, PVS-Cert judgements are used as verifiable certificates for predicate subtyping. In addition, the reduction → βσ is used to define a cut elimination procedure adapted to predicate subtyping. Its use to study the properties of predicate subtyp-ing is illustrated with a proof of consistency.
pvs-cert.pdf (386.92 Ko) Télécharger le fichier
hal-01977585 , version 1 (10-01-2019)
  • HAL Id : hal-01977585 , version 1
Frédéric Gilbert. Verifiable certificates for predicate subtyping. 2019. ⟨hal-01977585⟩
60 Consultations
133 Téléchargements
