Hybrid High-Order methods for finite deformations of hyperelastic materials, Comput. Mech, vol.62, issue.4, pp.909-928, 2018. ,
URL : https://hal.archives-ouvertes.fr/hal-01575370
A Hybrid High-Order method for incremental associative plasticity with small deformations, Comput. Methods Appl. Mech. Engrg, 2018. ,
URL : https://hal.archives-ouvertes.fr/hal-01768411
On the orthogonal subgrid scale pressure stabilization of finite deformation J2 plasticity, Comput. Methods Appl. Mech. Eng, vol.195, issue.9, pp.1224-1251, 2006. ,
Integrating a logarithmic-strain based hyperelastic formulation into a three-field mixed finite element formulation to deal with incompressibility in finite-strain elastoplasticity, Finite Elem. Anal. Des, vol.86, pp.61-70, 2014. ,
URL : https://hal.archives-ouvertes.fr/emse-01063686
Arbitrary order 2D virtual elements for polygonal meshes: part II, inelastic problem, Comput. Mech, vol.60, issue.4, pp.643-657, 2017. ,
Tne nonconforming virtual element method, ESAIM Math. Model. Numer. Anal, vol.50, issue.3, pp.879-904, 2016. ,
Convexity conditions and existence theorems in nonlinear elasticity, Arch. Rational Mech. Anal, vol.63, issue.4, p.77, 1976. ,
Numerical evaluation of discontinuous and nonconforming finite element methods in nonlinear solid mechanics, Comput. Mech, vol.62, issue.6, pp.1413-1427, 2018. ,
A virtual element method for elastic and inelastic problems on polytope meshes, Comput. Methods Appl. Mech. Engrg, vol.295, pp.327-346, 2015. ,
A nonconforming high-order method for the Biot problem on general meshes, SIAM J. Sci. Comput, vol.38, issue.3, pp.1508-1537, 2016. ,
URL : https://hal.archives-ouvertes.fr/hal-01162976
A Hybrid High-Order Method for Nonlinear Elasticity, SIAM J. Numer. Anal, vol.55, issue.6, pp.2687-2717, 2017. ,
URL : https://hal.archives-ouvertes.fr/hal-01539510
Hybrid Discretization Methods with Adaptive Yield Surface Detection for Bingham Pipe Flows, J. Sci. Comput, vol.77, issue.3, pp.1424-1443, 2018. ,
URL : https://hal.archives-ouvertes.fr/hal-01698983
The Finite Element Method for Elliptic Problems, 1978. ,
Implementation of Discontinuous Skeletal methods on arbitrary-dimensional, polytopal meshes using generic programming, J. Comput. Appl. Math, vol.344, pp.852-874, 2018. ,
URL : https://hal.archives-ouvertes.fr/hal-01429292
Unified hybridization of discontinuous Galerkin, mixed, and continuous Galerkin methods for second order elliptic problems, SIAM J. Numer. Anal, vol.47, issue.2, pp.1319-1365, 2009. ,
Bridging the Hybrid High-Order and hybridizable discontinuous Galerkin methods, ESAIM Math. Model. Numer. Anal, vol.50, issue.3, pp.635-650, 2016. ,
URL : https://hal.archives-ouvertes.fr/hal-01115318
F-bar-based linear triangles and tetrahedra for finite strain analysis of nearly incompressible solids. Part I: formulation and benchmarking, Int. J. Numer. Meth. Engng, vol.62, pp.353-383, 2005. ,
A Hybrid High-Order locking-free method for linear elasticity on general meshes, Comput. Methods Appl. Mech. Engrg, vol.283, pp.1-21, 2015. ,
URL : https://hal.archives-ouvertes.fr/hal-00979435
A Hybrid High-Order method for the steady incompressible Navier-Stokes problem, J. Sci. Comput, vol.74, issue.3, pp.1677-1705, 2018. ,
URL : https://hal.archives-ouvertes.fr/hal-01349519
An arbitrary-order and compact-stencil discretization of diffusion on general meshes based on local reconstruction operators, Comput. Methods Appl. Math, vol.14, issue.4, pp.461-472, 2014. ,
URL : https://hal.archives-ouvertes.fr/hal-00978198
A discontinuous skeletal method for the viscosity-dependent Stokes problem, Comput. Methods Appl. Mech. Engrg, vol.306, pp.175-195, 2016. ,
URL : https://hal.archives-ouvertes.fr/hal-01244387
Discontinuous Skeletal Gradient Discretisation Methods on polytopal meshes, J. Comput. Phys, vol.355, pp.397-425, 2018. ,
URL : https://hal.archives-ouvertes.fr/hal-01564598
A discontinuous Galerkin formulation for classical and gradient plasticity. II. Algorithms and numerical analysis, Comput. Methods Appl. Mech. Engrg, vol.197, issue.1-4, pp.1-21, 2007. ,
A discontinuous Galerkin formulation for classical and gradient plasticity. I. Formulation and analysis, Comput. Methods Appl. Mech. Engrg, vol.196, pp.3881-3897, 2007. ,
Finite element code_aster , structures and thermomechanics analysis for studies and research. Open source on www, pp.1989-2019 ,
Isogeometric analysis of nearly incompressible large strain plasticity, Comput. Methods Appl. Mech. Engrg, vol.268, pp.388-416, 2014. ,
URL : https://hal.archives-ouvertes.fr/hal-00938598
¯ B and ¯ F projection methods for nearly incompressible linear and non-linear elasticity and plasticity using higher-order NURBS elements, Comput. Methods Appl. Mech. Eng, vol.197, issue.33, pp.2732-2762, 2008. ,
Sur les matériaux standard généralisés, J. Mecanique, vol.14, pp.39-63, 1975. ,
A discontinuous finite element method for elasto-plasticity, Int. J. Numer. Meth. Biomed. Engng, vol.26, issue.6, pp.780-789, 2010. ,
A low order 3D virtual element formulation for finite elasto-plastic deformations, Comput. Mech, 2018. ,
A hybridizable discontinuous Galerkin formulation for non-linear elasticity, Comput. Methods Appl. Mech. Engrg, vol.283, pp.303-329, 2015. ,
A hybrid weakly nonconforming discretization for linear elasticity, Proc. Appl. Math. Mech, vol.16, issue.1, pp.849-850, 2016. ,
Hybrid Discontinuous Galerkin methods for solving incompressible flow problems, Rheinisch-Westfälischen Technischen Hochschule Aachen, 2010. ,
Mechanics of Solid Materials, 1994. ,
A fast convergent rate preserving discontinuous Galerkin framework for rate-independent plasticity problems, Comput. Methods Appl. Mech. Engrg, vol.199, pp.3213-3226, 2010. ,
On the spatial formulation of discontinuous Galerkin methods for finite elastoplasticity, Comput. Methods Appl. Mech. Engrg, vol.253, pp.219-236, 2013. ,
A discontinuous Galerkin formulation of a model of gradient plasticity at finite strains, Comput. Methods Appl. Mech. Engrg, vol.198, pp.1805-1820, 2009. ,
Anisotropic additive plasticity in the logarithmic strain space: modular kinematic formulation and implementation based on incremental minimization principles for standard materials, Comput. Methods Appl. Mech. Engrg, vol.191, pp.5383-5425, 2002. ,
Hybridizable discontinuous Galerkin methods for partial differential equations in continuum mechanics, J. Comput. Phys, vol.231, issue.18, pp.5955-5988, 2012. ,
A general discontinuous Galerkin method for finite hyperelasticity. Formulation and numerical applications, Internat. J. Numer. Methods Engrg, vol.68, issue.1, pp.64-97, 2006. ,
Algorithms for static and dynamic multiplicative plasticity that preserve the classical return mapping schemes of the infinitesimal theory, Comput. Methods Appl. Mech. Engrg, vol.99, pp.61-112, 1992. ,
Geometrically nonlinear enhanced strain mixed methods and the method of incompatible modes, Internat. J. Numer. Methods Engrg, vol.33, issue.7, pp.1413-1449, 1992. ,
, Computational Inelasticity. Springer, 1998.
Consistent tangent operators for rate-independent elastoplasticity, Comput. Methods Appl. Mech. Engrg, vol.48, issue.1, pp.101-118, 1985. ,
Variational and projection methods for the volume constraint in finite deformation elasto-plasticity, Comput. Methods Appl. Mech. Engrg, vol.51, issue.1, pp.177-208, 1985. ,
Discontinuous Galerkin methods for non-linear elasticity, Internat. J. Numer. Methods Engrg, vol.67, issue.9, pp.1204-1243, 2006. ,
Adaptive stabilization of discontinuous Galerkin methods for nonlinear elasticity: motivation, formulation, and numerical examples, Comput. Methods Appl. Mech. Engrg, vol.197, pp.3605-3622, 2008. ,
Adaptive stabilization of discontinuous Galerkin methods for nonlinear elasticity: analytical estimates, Comput. Methods Appl. Mech. Engrg, vol.197, pp.2989-3000, 2008. ,
A low order virtual element formulation for finite elastoplastic deformations, Comput. Methods Appl. Mech. Engrg, vol.327, pp.459-477, 2017. ,
A low-order locking-free hybrid discontinuous Galerkin element formulation for large deformations, Comput. Methods Appl. Mech. Engrg, vol.323, pp.353-372, 2017. ,
