ZoneMapAlt: An alternative to the ZoneMap metric for zone segmentation and classification - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2018
This paper proposes a new evaluation metric based on the existing ZoneMap metric. The ZoneMap method, designed to perform a zone segmentation evaluation and classification, is considered in the context of OCR evaluation. Its limits are spotted, described and a new algorithm, ZoneMapAlt (ZoneMap Alternative) is proposed to solve the identified limits while keeping the properties of the original one. To validate the new metric, experiments have been made on a dataset of scientific articles. Results demonstrate that the ZoneMapAlt algorithm provides greater details on seg-mentation errors and is able to detect critical segmentation errors.
zonemapalt.pdf (752.98 Ko) Télécharger le fichier
hal-01981628 , version 1 (15-01-2019)
Romain Karpinski, Abdel Belaid. ZoneMapAlt: An alternative to the ZoneMap metric for zone segmentation and classification. Document Analysis Systems, Apr 2018, Vienne, Austria. ⟨10.1109/DAS.2018.84⟩. ⟨hal-01981628⟩
78 Consultations
475 Téléchargements
