New interface
Conference papers
Inverse design of a suspended Kirchhoff rod: From theory to practice
Abstract : Our study focuses on finding the natural shape of a given hanging deformed isotropic rod, made of a known material, the input shape is described as a mere geometric curve that we subsequently frame to compute a material curvature field and feed our inverse problem. We prove that the natural shape of the rod satisfying equilibrium exists and is unique, regardless of the infinity compatible frames for the input curve. The natural shape is computed efficiently by solving in sequence three linear initial value problems. We illustrate our theoretical results trough numerical examples of well known curves to which we apply our inverse procedure. By direct simulation we show that indeed those natural shapes fall, under the effect of gravity, onto the expected equilibrium. We stress on the fact that the obtained rest shapes are complex and far from intuitive. Finally, we complement this study with experimental corroborations. By means of a standard array of cameras, we spatially reconstruct real elastic hanging rods with well-defined geometrical features. We find some good agreements with model prediction despite the experimental limitations on the estimation of the curvature fields of the rod’s center line.
Complete list of metadata
https://hal.inria.fr/hal-01981923
Contributor : Victor Romero Connect in order to contact the contributor
Submitted on : Wednesday, April 7, 2021 - 12:06:18 PM
Last modification on : Tuesday, August 2, 2022 - 4:24:57 AM
Long-term archiving on: : Thursday, July 8, 2021 - 7:04:57 PM
APS_2019_abstract.pdf
Identifiers
  • HAL Id : hal-01981923, version 1
Citation
Victor Romero, Florence Bertails-Descoubes, Alexandre Derouet-Jourdan, Arnaud Lazarus. Inverse design of a suspended Kirchhoff rod: From theory to practice. APS 2019 - American Physical Society March Meeting, Mar 2019, Boston, United States. ⟨hal-01981923⟩
Share
Metrics
Record views
188
Files downloads
94
