A Primer on PAC-Bayesian Learning - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2019
Generalised Bayesian learning algorithms are increasingly popular in machine learning, due to their PAC generalisation properties and flexibility. The present paper aims at providing a self-contained survey on the resulting PAC-Bayes framework and some of its main theoretical and algorithmic developments.
main-bguedj.pdf (509.33 Ko) Télécharger le fichier
hal-01983732 , version 1 (16-01-2019)
hal-01983732 , version 2 (21-04-2019)
hal-01983732 , version 3 (07-05-2019)
  • HAL Id : hal-01983732 , version 2
Benjamin Guedj. A Primer on PAC-Bayesian Learning. 2019. ⟨hal-01983732v2⟩
176 Consultations
294 Téléchargements
