Asymptotic behaviour of a network of neurons with random linear interactions - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2020
We study the asymptotic behavior for asymmetric neuronal dynamics in a network of linear Hopfield neurons. The interaction between the neurons is modeled by random couplings which are centered i.i.d. random variables with finite moments of all orders. We prove that if the initial condition of the network is a set of i.i.d. random variables and independent of the synaptic weights, each component of the limit system is described as the sum of the corresponding coordinate of the initial condition with a centered Gaussian process whose covariance function can be described in terms of a modified Bessel function. This process is not Markovian. The convergence is in law almost surely with respect to the random weights. Our method is essentially based on the method of moments to obtain a Central Limit Theorem.
asymp_V5.pdf (320.04 Ko) Télécharger le fichier
hal-01986927 , version 1 (21-01-2019)
hal-01986927 , version 2 (04-06-2020)
  • HAL Id : hal-01986927 , version 2
Olivier Faugeras, Emilie Soret, Etienne Tanré. Asymptotic behaviour of a network of neurons with random linear interactions. 2020. ⟨hal-01986927v2⟩
311 Consultations
211 Téléchargements
